Vararam
Old 03-13-2024, 04:15 PM   #1
Jasonhunt82
Drives: 2013 Camaro SS 2SS
Exclamation 6l80 tuning question!!
Last year, the 6l80 transmission failed, prompting a complete overhaul with billet parts from Circle D transmissions, capable of handling up to 1000hp. Despite currently running at 701hp to the wheels, I took it for tuning after adding a 3200 converter, assuming it needed tuning I took it to the tuner. They set transmission to relearning, and I didn't think much of it at the time since they had tuned it before. However, the gas mileage has significantly worsened, now at 27L per 100kms (8.7mpg). After investing nearly $10k in the rebuild, I'm eager to ensure it's properly tuned, as I understand that a faulty tune alone can lead to transmission failure.
If anyone has any insight or knowledge that would be awesome.
Jasonhunt82 is offline   Reply With Quote
Old 03-13-2024, 04:30 PM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
It's kinda hard to find a good tranny tuner but one of the most important things you need to do. I found out that Ryan at GPI is one of the best engine and tranny tuners out there. So if I was you I would pay to get an email tune from them. There's just too many variables in the trans tune to let anybody do it. Another thing is torque reduction, I have all that crap turned off.
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is online now   Reply With Quote
Old 03-13-2024, 06:22 PM   #3
HuZL1n
Drives: 2013 Camaro ZL1 Vert
Look at Justin White (Justin White Tuned) or Tim King (TK Transmissions). I haven't used them, but they are supposed to be the best in the business for trans tuning on LS/LT based motors.
HuZL1n is offline   Reply With Quote
Old 03-14-2024, 02:01 PM   #4
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Do you have HPTuners?
If so, look up BlueCat tuning and plug your info in and it spits out the variables needed to put into HPT and works great
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 03-15-2024, 08:41 AM   #5
Jasonhunt82
Thanks a lot peeps
Old 03-15-2024, 10:19 AM   #6
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
I had Steve at 6L80tuning.com tune my car. The transmission tune is spot on and we'll worth it.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
