10-30-2023, 04:15 PM | #15 | |
10-30-2023, 05:21 PM | #16 |
Agreed. Bo White and a couple other guys have said the same when folks are looking for a budget friendly performance mod. Do a stall first, then if you need more, a gear swap. This way if you are going to do a cam swap in the near future, you're all set with a stall. At least a 3200 which is good they say for a stock Camaro. Wish I knew that when I first started modding. I never did a gear swap on mine as I didn't feel the need to do so. The way she runs now with the 4500 and gets off the line from a dead stop, and from a 45 or 50 mph roll is absolutely astonishing and amazing!! The reason I didn't do the gear is I cruise a lot and just didn't want to be turning the extra RPM's.. Plus my solid cradle mounts and 1 pc DS adds a ton of instant gratification.
10-30-2023, 05:25 PM | #17 |
^^^ Exactly what joe said. My tuner when we did the dyno tune, and when I went back to have the tune adjusted for the 4500 from the 3200, also did a street tune with the trans to make sure all was functioning well as it should. And yep, a good trans cooler IS a must!!
10-30-2023, 06:35 PM | #18 |
Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
Ah okay, after reading this thread I was thinking of maybe changing plans to be:
Torque converter->trans support mods(cooler, deeper pan)->cam with supporting mods and tune But if the torque converter is going to need a tune and transmission support mods regardless it might just be worth it to take like a week of vacation time and pull the engine to do it all at once, less downtime and less tunes, granted I'm probably at least a year away from being able to financially justify it all, so learning and planning is what I got going now
Behind every scratch is a story on what not to do, and my car has a lot of stories.
10-30-2023, 07:15 PM | #19 | |
11-01-2023, 11:46 AM | #20 |
I keep hearing good things about Dyno Steve and him doing updates free so I was thinking of going that route, my biggest concern is downtime, the car is still my daily, while I can harass my friend with a lift to let me use it and get the torque converter knocked out in a weekend, I'm guessing there are probably few weekdays involved in having it run well, and I can take some days off or find a car to borrow but obviously I wanna minimize that. It kinda sucks and I have money saved up for a second car right now I just don't have anywhere to park it, looking at maybe getting that fixed this coming summer but not getting hopes up.
11-01-2023, 06:23 PM | #21 | |
I would go with GPI personally
ABM #2399 2SS/RS:SOLD
11-02-2023, 08:54 AM | #22 |
Drives: 2016 1SS Join Date: Apr 2012
Cam Specs
What is the Lobe Separation on the cam you picked.
11-02-2023, 09:11 AM | #23 |
All the info is in my sig.... TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT
11-02-2023, 03:19 PM | #24 |
Sorry, I missed that. Thank you.
11-02-2023, 04:03 PM | #25 |
Drives: 2011 Camaro SS Join Date: Jul 2017
My 1st mod was a stall and trans cooler. I went with a 3600 single disc with the stock cam. It was a night and day difference. My combo has changed quite a bit since then.
