08-04-2017, 10:54 AM | #1 |
Drives: 2015 2SS White Convertible CE/INDY Join Date: Mar 2016
Muffler Delete
Well, I just got my muffler delete done yesterday. So far I am very happy with the sound of my system. The tone is about 90% of what I want and the volume is about the same... Not too loud under normal driving but gets some good volume when I get on the pedal. It's still hard to believe that having no mufflers gives the volume that it does. With other cars I had, a small hole in the muffler made it crazy loud... I had my stock tips put back on.
I think that my next upgrade might be cut-outs instead of a whole new exhaust system...but I'll wait a little before I go that route. joe....
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
08-14-2017, 11:53 AM | #2 |
So after a couple of weeks of my muffler delete, I am really liking this option. My exhaust system is stock... The thing is, the AFM was much louder when I had my aftermarket mufflers put on. Now with the delete, I can still hear it, but its no longer amplified by the muffler so that it's almost not as noticeable.
08-14-2017, 02:45 PM | #3 | |
Drives: 2015 Camaro SS convertible L99 Join Date: Nov 2016
08-14-2017, 03:56 PM | #4 |
I still have the butterflies on because I believe they are needed for back pressure when going into 4cyl mode. If I was to get a full cat-back system (eliminating those valves) then I would need to use my Range all the time or, I would need a tune. But honestly, it's not as bad as I thought.
08-16-2017, 10:31 AM | #5 |
[QUOTE=GodWentPunk;9865765]I still have the butterflies on because I believe they are needed for back pressure when going into 4cyl mode. If I was to get a full cat-back system (eliminating those valves) then I would need to use my Range all the time or, I would need a tune. But honestly, it's not as bad as I thought.[/QUOT
I had a feeling you kept them. Those things keeps the exhaust quite at idle and in cruise. |
08-16-2017, 01:24 PM | #6 |
If that's all they do, then maybe I'll try to move the springs to keep them open all the time.
