03-12-2019, 10:09 AM | #1 |
Drives: 2011 Camaro SS Join Date: Dec 2016
I broke a latch on my airbox
I was checking my Camaro to get it ready for warmer weather and broke one of the latches off the factory airbox. 100% my fault, I didn't get the lid lined up correctly and pushed down to hard in temperatures were the plastic was likely brittle.
The airbox seems to still close and seal ok. I'm wondering if I should rig up a replacement latch or just pony up for a new airbox. I see they are about $120 new for the whole OEM assembly. I guess it could be an excuse for a CAI, but I don't plan to do an aftermarket exhaust for the car so that's probably wasted money. |
03-12-2019, 10:20 AM | #2 |
Instagram: Sangstah
I would just get a used CAI from on here for the price of a new airbox
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
03-12-2019, 11:47 AM | #3 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
This^^^
603 h.p. 495 ft lbs tq. |
03-12-2019, 12:06 PM | #4 |
376 cubic inches of fun
$120 seems like a small price to pay for your mistake.
Others will have to weigh in on whether you need a tune after installing CAI, and whether there's a risk of ingesting water when driving at high speeds in the rain. |
03-12-2019, 01:16 PM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Duct tape!
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
03-12-2019, 02:49 PM | #6 | |
Drives: 2010 SS L99 Join Date: Sep 2018
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
03-12-2019, 03:18 PM | #7 |
Instagram: Sangstah
I think the only CAI you need a tune for is the Vararam. Ran my K&N blackhawk intake without tune for a while with no issues. Also heavy rain is no issue even with my ADM air scoop in the lower grill.
03-12-2019, 09:19 PM | #8 | |
...you know, since duct tape comes in a variety of colors these days that could be my fix AND customization at the same time.
Thanks, I'll consider it. Despite the appeal of the duct tape mod, I'll probably troll through some scrapyards and see what I find. In the grand scheme of things, I suppose so. That'd buy a lot of duct tape, though... |
03-12-2019, 11:30 PM | #9 |
Drives: Miss Con Ception Join Date: Aug 2016
Drill a pilot hole in the top of the box next to the latch and run a 1/4" TEK screw through it. Once threaded cut the tip off the screw. Use a nut driver for the old in and out.
2011 1SS/RS LS3 CGM
03-13-2019, 08:17 AM | #10 |
Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
Where are you located in IN? I'll give you mine if you're close
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
03-13-2019, 09:45 AM | #11 |
I went through three airboxes on mine because the tabs and inserts kept breaking off, surprised yours lasted this long. After the last one broke I bought a R2C intake with their black hex filter and called it a day.
On a side note the R2C gave me a 3mpg jump in fuel economy.
The Mistress: Cam Motion custom VVT grind, shaved heads, R2C intake, Solo mids, 1LE suspension, BMR tunnel brace, GPI tuned, among other bits.
03-13-2019, 10:24 AM | #12 |
03-13-2019, 12:25 PM | #13 | |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
03-13-2019, 09:12 PM | #14 |
Indy. That's very nice of you. If I can't find something local and can resist the allure of duct tape, I'll get in touch with you. We've not been to Ft. Wayne in a while anyway and I'd not mind an excuse to visit the Hoppy Gnome again.
