03-31-2015, 01:44 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
2" primaries vs 1 7/8's for blower setup?
I currently have the kooks LT's with their High flow cats and i just bought yesterday the Corsa ZL1 exhaust 3" cat back. Do i honestly need the 2" primaries?
03-31-2015, 01:51 PM | #2 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
I think you might need 7-800rwhp to see any gains from them.
03-31-2015, 02:35 PM | #3 |
Drives: 2006 Z06 Join Date: Oct 2010
I made 1090 on 1 7/8. No need unless going for 1100+ IMO
Nick
Corvette Z06 -1200ish rwhp |
03-31-2015, 02:59 PM | #4 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
If I was buying I would buy 2 for your setup,since you already have headers I wouldn't think it would be worth swaping unless money is no object.
03-31-2015, 03:21 PM | #5 |
03-31-2015, 03:22 PM | #6 |
03-31-2015, 04:32 PM | #7 |
1 7/8" will support more than that blower can ever make. If buying new with a blower, do like HE said and get some 2s, but 1 7/8 are not going to hold you back at all.
Nick
03-31-2015, 04:52 PM | #8 |
Sounds good brotha. Just was pondering the idea of upgrading. Hopefully this well help answer some of the other forum members questions as well.
03-31-2015, 05:21 PM | #9 | |
2012 Camaro JRE 416 Vortech YSI. Hope this helps. Ted.
www.jannettyracing.com
03-31-2015, 07:33 PM | #10 |
whippled 5th gen
i am good with 1 7/8 long tubes on my setup, considered going to 2 inch long tubes but didn't seem worth the cost, would rather use the money to put toward some ported heads to help the engine breathe better, it all comes down to how much power you want to make.
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
03-31-2015, 09:39 PM | #11 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
03-31-2015, 09:40 PM | #12 |
Drives: T Join Date: Mar 2015
do you want the biggest and the baddest?
2" |
04-01-2015, 10:01 AM | #13 |
Drives: 2003 corvette vert Join Date: Mar 2014
how about torque ted?
Xxxx
04-01-2015, 10:12 AM | #14 |
Up as well everywhere sorry don't recall exactly.
