06-25-2020, 09:58 PM | #1 |
Drives: '18 Camaro ZL1 Join Date: Feb 2014
ZL1 Sway under throttle
New ZL1 owner here, upgraded from a 5th gen 1LE so made a pretty big leap. Noticed some sway when I really get on the throttle, back end feels really light and sways even when I feel I have it pinned. Any suggestions? Just something to get used to?
06-25-2020, 10:03 PM | #2 |
Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
What tires are you running in the back? Is your car stock?
06-25-2020, 11:18 PM | #3 |
Yep it’s that new found supercharged 650 hp in your ZL1 as compared to your 5th gen 1LE! Get used to it and enjoy driving that beast!
06-25-2020, 11:21 PM | #4 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
BMR lock out kit in the rear with help, along with their upper/lower trailing arms. Really solidified the rear end on the track.
06-26-2020, 01:20 AM | #5 |
Drives: 2020 RGM ZL1 Join Date: Jun 2020
Either the bmr lockout kit plus trailing arms or the gmp solid rear cradle bushing. Either one will lock down that rear end for you.
'20 ZL1 Rally Green Metallic
-work in progress '06 GTO Spice Red (RIP) -Full Pedders, K&N, Ported TB, FAST Manifold, SW Exhaust, Stoptech Brakes, DBA5000XS |
06-26-2020, 01:46 AM | #6 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
I honestly love that feeling. Like it's stepping out but isn't.
06-26-2020, 06:33 AM | #7 |
Drives: 2018 ZLE Join Date: Feb 2018
I get the same feeling when I get on mine. I kinda enjoy it.
06-26-2020, 06:41 AM | #8 |
Drives: 2017 ZL1 Camaro Join Date: May 2018
If you're looking to fix the issue I would have a quality alignment done first before replacing parts. One other item to check is the condition of the rear tires and confirm even wear, also obviously tire pressure.
I have zero tail wag in my car, its 100% stock other than the alignment. Its straight as an arrow at WOT, unless the rear tires let loose and spin.
2017 Garnet Red ZL1 A10
Other Rides, 97 Trans Am, 72 Chevelle |
06-26-2020, 06:56 AM | #9 |
Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
this was discussed in depth in this thread.. hope it gives you the info you need. Its a wide range of opinions all seem to be good. let us know what your fix is for this...
https://www.camaro6.com/forums/showthread.php?t=576545
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
06-26-2020, 07:34 AM | #10 |
06-26-2020, 07:39 AM | #11 | ||||
Thanks for the advice! Will definitely take a look at them after the below is performed. Quote:
I honestly believe this is what it may be. My initial gut was to get it checked out asap but i would figure that I would ask to see if there was something else feature wise that I'm not aware of that would minimize it. Mine is 100% stock with less than 9000 miles and the previous maintenance records looked promising but still plan on having another alignment done. Quote:
Much appreciated! Google failed me a few times in my searches, but will definitely check this thread! |
06-26-2020, 09:54 AM | #12 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
I get the tail wag as well, but the traction control is screaming when that happens
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
06-26-2020, 01:23 PM | #13 |
Drives: 2018 ZL-1 Join Date: Jan 2018
I have had that problem even after the BMR cradle lockout kit, as well as BMR toe rods, control arms, trailing arms and cradle braces.
Alignment is very important. Also, as suggested in the other thread, turning off traction control helps quite a bit. |
06-26-2020, 03:33 PM | #14 |
Be cautious of your dealer doing your alignment if you do not have a high level of trust working with them. The first two alignments done to my car were from the dealer and they were both garbage, I honestly think it was user error because they have quality alignment machines and the "print outs" looked good that were given to me after the alignment. The street driving and track manners said something completely different which left me frustrated and questioning the car.
I ended up finding a locally owned truck shop that had a new Hunter Eagle Eye alignment machine and worked with the tech on getting the specs I wanted and wow did it ever make a difference. Street driving was noticeably better but on the track it was an incredible improvement, very neutral and predictable after the track alignment. Worth every penny.
