08-22-2023, 04:30 PM | #1 |
P0305 Bad Gas or Dirty MAF
After driving about 10 miles after getting 3/4 tank of Shell 93 octane from a busy station I never got gas from before I get flashing CEL and Service Stabilitrac msg with car running like shit. I’m thinking bad gas and fearing the worst as the pump kept cutting out on the attendant and knowing we CANNOT siphon gas from our tanks.
I’ve owned the car 11 yrs / 49k miles and only had one other CEL about 3 yrs ago and that was after gassing up at another Shell station I never used before, but that time it was only a CEL. In the interim yrs I always got gas from same Exxon station. Knowing I can’t siphon the tank I put in a can of isoHEET thinking if it’s bad gas that would help. Nope, lights still on car running like crap in 1st. So I figured WTH I’ll clean the MAF before taking to garage to change plug, injector, etc. After a few drive cycles at no more than 2k rpm all lights go off and car is running fine …really BTW my SCTX4 wouldn’t clear the code |
08-23-2023, 08:02 AM | #2 |
Drives: 2010 Camaro SS2 2012 C6 vette M6 Join Date: Jan 2022
Its goodto run some Lucas or Seafoam injector cleaner every now and then
. Helps with the misfires and the crap gas . |
08-23-2023, 08:38 AM | #3 |
You can Siphon Gas my friend. I have already done it twice, once to remove old gas, and once to install a ZL1 FP.
Post #21 https://www.camaro5.com/forums/showt...=267747&page=2 |
08-23-2023, 09:45 PM | #4 | |
08-24-2023, 05:10 AM | #5 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Just be careful if you use the remove the hose method. The hose is discontinued or going to be soon from GM so if you tear a hole in it or something, it won't be a good day.
Ah, just checked. You can still buy one. P/n 92225312 but now it's list price is $172.04. Yeah, you read that right. Not a typo. The neck assembly which includes the hose lists for $257.55 Now's a good time for the reproduction folks to jump in on that, you know, just in case. Dorman MIGHT have something, but not sure.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
