dave@hennessey
Old 07-09-2022, 07:59 AM   #1
camguynj
camguynj's Avatar
Clutch Return Spring Install
How do you put the spring on? Middle first then sides, sides first then middle or one side first then middle then other side? Thanks
Old 07-09-2022, 01:43 PM   #2
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Are you putting stock one back on and if so why? I am getting ready to remove mine and just wondering.
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 07-09-2022, 02:09 PM   #3
camguynj
camguynj's Avatar
Yes, putting stock one back on. Had it off for little over a week and want to see if pedal depression feels any ezer with spring on. Pedal release/engagement is definitely smoother /more linear
Old 07-10-2022, 05:32 AM   #4
Joe.G
Joe.G's Avatar
Please post back your findings, I have this on the way https://www.lingenfelter.com/product...l#.YsqqfITMJEZ
Going to try with out stock spring and then with the linked spring above.
SCT X4 Dynosteve,
Old 07-18-2022, 01:49 PM   #5
Joe.G
Joe.G's Avatar
Did you get it installed again? Thoughts?
SCT X4 Dynosteve,
Old 07-18-2022, 05:16 PM   #6
camguynj
camguynj's Avatar
Not yet. After trying a while I think the middle of the spring has be inserted into its slot first, then both sides need to be compressed simultaneously in order to shorten the spring to fit in the space you have to work with in order to insert the ends into their slots. There just didn't seem to be enough space to compress & insert one end at a time. It maybe that you even have to depress the pedal to provide enough room to compress & inserts the ends? In order to compress both sides of the spring simultaneously you need channel lock plyers which I don't have so I put off doing it for the time being.
Old 07-18-2022, 05:32 PM   #7
Joe.G
Joe.G's Avatar
Yeah I popped one side out and tried to snap a pic if I wanted to put it back in, I am not sure what the best way would be, It is really tight down there. Hopefully I won't be putting it back in.
SCT X4 Dynosteve,
