12-16-2018, 06:04 PM | #1 |
Drives: Camaro Join Date: Sep 2018
Cats Question
If I gut all the cats I know I will get a CEL, but can I use my code reader just to erase the codes? Will the CEL come back after erasing the codes? I will still connect O2's back up after gutting them, just wondering if this will work.
Or is it better to buy the straight pipes to replace the cats? |
12-16-2018, 06:57 PM | #2 |
Drives: 2018 SS 1LE Join Date: Apr 2017
If you remove or replace the catalytic converter your CO2 sensors will cause your car to throw the codes. Clearing the codes won't work.
12-16-2018, 07:21 PM | #3 |
12-16-2018, 07:41 PM | #4 |
Drives: 19 SS 1LE Join Date: Nov 2018
Not remove your cats. It stinks up the road for everyone else.
I believe if you remove the secondary cats you can avoid a CEL with a plug Fowler adapter. But to be 100% sure of no CEL, with all cats removed, you’d need your ECU retuned via aftermarket. |
12-16-2018, 10:50 PM | #5 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
You wont get a CEL until you delete the primary cats then at that point you'll need your tuner to turn the codes off or use HP tuners.
12-17-2018, 06:09 AM | #6 |
Once the Whipple gets installed I don't want any cats, to much back pressure for a supercharger IMO. HPtuners comes with my Whipple so that will be great.
12-17-2018, 06:26 AM | #7 |
Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
Yup, just tune them out.
2017 1SS M6 Hyper Blue Metallic NPP, MMR 228 Z/28 replica wheels, Front: 20 x 9, Rear 20 x 11
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
12-17-2018, 07:23 AM | #8 |
Drives: 2021 300 Join Date: Jan 2015
Removing Cats on a Street car is a $10,000 federal crime.......
12-17-2018, 07:30 AM | #9 |
Drives: 18 zl1 Join Date: Aug 2017
removing the converter is illegal. getting caught without one isn't.
you are right about the "up to" fine for removing it, but getting caught without it will usually just get you a smog ticket or the like, which even then can be overthrown if you reinstall one. |
12-17-2018, 07:31 AM | #10 |
Been doing it since 1979 & Oklahoma has no emission inspections anymore.
12-17-2018, 07:35 AM | #11 |
Drives: 18 2SS 1LE Join Date: Jul 2018
12-17-2018, 07:37 AM | #12 |
no working taillights huh. I think my cars are the only ones here that have blinkers that work.
12-17-2018, 07:43 AM | #13 | |
Oklahoma is one of the few states that do not require emissions checks for motor vehicles. An emissions inspection is not needed to register a vehicle in Oklahoma, irrespective of the age of the vehicle. |
12-17-2018, 08:54 AM | #14 | |
Drives: 2017 Camaro SS 2SS Join Date: Jun 2017
