BeckyD @ James Martin Chevy
Old 09-30-2022, 01:36 AM   #1
Sillysspeed
Drives: 98 Camaro
Lt2 manifold dragy times
So I got all the parts to put the lt2 manifold in and got it installed this eve. I actually used some 10” high leverage knipex cutters to trim the underneath plastic. Worked better than the burr bit IMO. Installed brake booster fitting with a good amount of thread tape. Ict map extension you really had to use some pressure to get clipped. Trimmed the sound deadener underneath the manifold to fit and re installed the stock throttle body. There was already oil in the intake. Car only has 650 miles on it. So I installed the might mouse can also. Slight pita to install but it went on eventually after trying to fight me. Went out to Mexico afterwards to see if I could notice a difference in performance. I was rewarded with a new best slip. I made 3 passes this one being the best. All similar tho. Air was -40da. Last time out was 120+da so pretty similar. The dragy is always off on da and elevation. Car just continues to impress me.
Sillysspeed is offline   Reply With Quote
Old 09-30-2022, 08:12 AM   #2
Danew_377
Chief Bief
Danew_377's Avatar
Drives: Nightfall Gray Camaro 1SS
Hoping to do the swap today. Good numbers there.
2016 NFG 1SS M6
JLT Intake, LT2 Manifold, LT5 TB, CSP 2" headers, AWE Catback Exhaust, Apex ARC-8 Wheels.
426whp/434wtq
Danew_377 is offline   Reply With Quote
Old 09-30-2022, 09:46 AM   #3
Sillysspeed
Drives: 98 Camaro
That’s cool man. Yea some people say it only takes an hour but it was around 4 hours to modify it and install and then put catch can on
Old 10-01-2022, 03:08 PM   #4
Tripwire1124
Tripwire1124's Avatar
Drives: 2022 LT1 Camaro
Good stuff! Just lt2 and and air filter right? Have you any other things done?
10.92 @129.3mph
Tripwire1124 is offline   Reply With Quote
Old 10-01-2022, 04:21 PM   #5
Sillysspeed
Drives: 98 Camaro
SS wheels on rear with some Bridgestone tires. Removed plastic shield and drop in k&n.
Old 11-09-2022, 02:50 PM   #6
BlackV6RS
Drives: Wild Cherry 2021 Camaro LT1 RS
Was this without a tune?
BlackV6RS is offline   Reply With Quote
Old 11-09-2022, 06:35 PM   #7
red6.2
Drives: 2010 camaro
yup. lt2 is legit. you could tell the torque difference as well. I also picked up 2mph in the 1/4mile.
red6.2 is offline   Reply With Quote
Old 12-10-2022, 10:49 AM   #8
V8RWD
V8RWD's Avatar
Drives: 2017 Camaro SS 50th
I feel like the great times were achieved by mostly driver mod. 1.78s 60ft on street bridgestone tires? That is fantastic, better than many with drag tire times I've seen. Anyway, with a 60ft time like that, high 11s is expected even with stock intake manifold. The fact that 1/8th mile is a really quick mid 7 second also confirms rest of the way is pretty inline with bone stock Camaros. (Hopefully I'm not off here.)
V8RWD is offline   Reply With Quote
Old 12-10-2022, 04:52 PM   #9
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Hey tripwire, what are all your mods to be running 10.90s?
lt4camaro is offline   Reply With Quote
Old 12-10-2022, 06:03 PM   #10
LT1ornothing
Drives: 2020 LT1 M6
https://www.camaro6.com/forums/showthread.php?t=609798
Here you go, if you click on his name, and click on "see all posts by" you can read about his set up. Just takes a few clicks and a bit of reading.
[SBE] ECS NOVI 1500 supercharger, 2" Longtube headers, flex fuel, LT4 injectors, LT4 HPFP, baro breakout
Tune date and results to be determined
LT1ornothing is offline   Reply With Quote
Old 12-14-2022, 12:00 AM   #11
Sillysspeed
Drives: 98 Camaro
Yes if you can get the hard tires to hook they will go a little quicker than drag radials. I run 25psi in them also where drag radial usually around 16-18psi. The 11.78 was with the stock manifold. K&n and shroud delete.
Old 12-14-2022, 08:49 AM   #12
lt4camaro
lt4camaro's Avatar
Run the car in a more realistic higher DA at a drag strip a few times and show the time slip. a 11.78 with a 1.78 60 ft on shit tires is much quicker the a bone stock automatic SS or LT1 with a LT2 intake and no other mods in my opinion.
Old 12-14-2022, 11:46 PM   #13
Sillysspeed
Drives: 98 Camaro
It’s actually a good tire. Has worked well for me. Very expensive though. The DA is the DA. I cant get to the track much so I go out after the fam is asleep and Mexico is open. Only time I did my first pass was an 11.99 time slip and the dragy read a 12.01. That was stock in touring mode. I didn’t figure out sport mode til after. I’m pretty good at getting the best out of cars. I’ve been doing this a while now
