Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Transmissions
BeckyD @ James Martin Chevy
Old 04-12-2020, 01:09 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
wtb a shifter detent tr6060 or t56
i want to get one to try and put a lighter spring in it for the hurst shifter. something better then the anti venom mod.
Old 04-12-2020, 07:17 AM   #2
DorkMissile
DorkMissile's Avatar
Drives: 18 1SS 1LE HyperBlue
It might be worth giving Tick a call - if anyone knew anything about it, they might.
You could take it apart, cut a coil or two off, stretch it out to about the same length and that would soften it up also.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
DorkMissile is offline   Reply With Quote
Old 04-12-2020, 07:40 AM   #3
6spdhyperblue
Drives: 6th gen
How do u get it apart
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
6spdhyperblue is offline   Reply With Quote
Old 04-12-2020, 10:22 AM   #4
JCunningham
Drives: 2017 2SS M6
cut it. putting it back together id have to figure out.
Old 04-12-2020, 10:28 AM   #5
6spdhyperblue
Drives: 6th gen
Oh man. Interesting. Wonder if the top where the spring seats can be drilled out and then threaded so we can drop the modded spring in there and thread on a cap or weld it?
Old 04-12-2020, 11:21 AM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I bet it’s just pressed in and lock-tited. Maybe a heat and a screwdriver?
Orange Krush II
Old 04-12-2020, 10:39 PM   #7
blk 2013
blk 2013's Avatar
Drives: 2017 SS 6sp
whats wrong with adding washers?
blk 2013 is offline   Reply With Quote
Old 04-12-2020, 10:48 PM   #8
JCunningham
Drives: 2017 2SS M6
the stick flops around and makes it harder to find gears. Im down to 1 thin dorman copper washer and you can hear it tapping the ball bearing a idle. the shifter needs a little resistance on it. with the any washers its not touching the shifter so it will just flop around . With the 1 washer 1-4 feel ok but 5th feels like your putting it in reverse and its harder to find because the resistance is so much more. if there were no washers and the detent had a weaker spring all gears would feel the same.
