Old 04-06-2020, 11:44 PM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
zl1 brake pad replacement?
i know the bolt tq just want to know if theres anything to replacing the pads? any grease. i have factory pads with the rubber anti squeak pad on that comes on them. the 2017 Factory shop manual does not have J6H brakes in it
Old 04-08-2020, 08:18 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
no grease necessary
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 04-09-2020, 06:42 AM   #3
JCunningham
Drives: 2017 2SS M6
what about the torque spec for the center bolt on the front 6 piston BZ-61. should i use loctite? high temp? any anti seize on the sides of the pads? would realy like a copy of the factory instructions. I just bought one of those manual copies on cb of the 18 manyal hope its in that one sense its not in the 17 for the J6H brakes.
Old 04-09-2020, 07:24 AM   #4
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Torque spec is 22 lb-ft for the bridge pin bolt (center bolt). Factory manual does not call for any, but you can use a small amount of blue (low strength) thread locker if you want. High strength will likely snap the bolt off inside the pin the next time you try to remove it since it's a pretty small bolt.
As Stephen previously mentioned, no grease or anti-seize is needed. Just take the old pads out and put the new ones in.
For factory manual process, the how-to guides on the forums do a pretty good job of covering it. Nonetheless, basic steps are:
  1. Drive pad retainer pins out.
  2. Remove pad spring.
  3. Remove bridge pin.
  4. Pull old pads out.
  5. Use spreader or other wide/flat tool to move all pistons back at once. Keep an eye on the brake fluid reservoir to make sure you don't overflow during this step.
  6. Slide new pads in.
  7. Put bridge pin back in and torque to 30 Nm (22 lb-ft).
  8. Put spring back in.
  9. Drive pad retainer pins in.
  10. With engine off, slowly push brake pedal to about 2/3 of full travel and slowly release.
  11. Repeat previous step until brake pedal becomes firm.
  12. Top off brake fluid if needed.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 04-09-2020, 07:34 AM   #5
Stephen12ZL1
Drives: '21 ZLE A10
don't overthink this process...it is absolutely the easiest pad swap ever. Watch orientation of the spring as it has an arrow pointing up. 13mm for the bridge bolt. Don't over torque the bridge bolt as a few have snapped it. Make sure to crack open the master cylinder reservoir before depressing the pistons and replace one pad then the other. Don't remove both pads as the pistons will block the path for the new pad when you depress.
