BeckyD @ James Martin Chevy
Old 02-22-2020, 03:45 PM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
anyone who has installed the GM aluminum cradle bushings?
how did you get them in? you are supposed to make sure then go in straight. I have a piece of threaded rod with nuts and washers. it keeps kicking sideways.
Old 02-28-2020, 03:48 PM   #2
L78toLT1
L78toLT1's Avatar
Drives: Hyper Blue 2016 2SS 6M
Try putting them in the freezer overnight
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned
L78toLT1 is offline   Reply With Quote
Old 02-28-2020, 10:38 PM   #3
JCunningham
Drives: 2017 2SS M6
DO NOT DO IT THIS WAY. YOU HAVE TO INSTALL THE TOP BUSHING 1ST SO IT WILL GO IN ALL THE WAY. THE BOTTOM CAN STICK OUT BUT NOT THE TOP. Now i have to find out how to get the top bushing fully seated. did that did help. i ended up just using a 6" 3/4" bolt with 6 washers. like this https://www.youtube.com/watch?time_c...ature=emb_logo
Old 03-01-2020, 01:35 AM   #4
JCunningham
Drives: 2017 2SS M6
edited lst post. DO NOT DO IT LIKE THIS VIDEO.
Old 08-01-2020, 01:42 PM   #5
20Bluezl1
Drives: 2020 Zl1 A10 Riverside Blue
So what is the proper way to install the ZLE Cradle bushing?
20Bluezl1 is offline   Reply With Quote
Old 08-01-2020, 09:04 PM   #6
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
Hmmm...I don't understand what you're saying here?
Do it like the video?
Don't do it like the video?
And what do you mean by "did that help".
So did you get it installed, and if so, what did you do?
I have a set coming, and would like to get a heads up on this.
Thanks!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
