Old 09-05-2019, 11:48 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Torque to yield bolt number thread TTY bolts
Im hoping to get this stickied so we have a list of bolt numbers. I will add non tty bolts to. please dont reply to this thread unless you have part numbers for me. thanks part numbers are in post #2
Old 09-05-2019, 12:00 PM   #2
JCunningham
Drives: 2017 2SS M6
Caliper Bolts (SS, SS/1LE, ZL1, ZL1/1LE) reusable GM says you have to replace them but then they say you can reuse them in the performance sections.
front #11611085
rear#11570091
__________________________________________________ __________________________________________________ _____________________________
Alignment bolts TTY
11547215 Lower Control Arm Bolt, Left INNER
11547215 Lower Control Arm Bolt, Right INNER
11547262 Lower Control Arm Washer, Left and right the bolts in your car may be different but these are the replacements. you will need this washer to go on the replacement LCA BOLTS.
11611276 Link Rod Bolt, Right INNER
11611276 Link Rod Bolt, Left INNER
YOU CAN REUSE THE WASHERS AND NUTS WITH BLUE LOCTITE
Rear cradle bolts
front 11547921 qty 2
rear 11611819 qty 2
ill finish this later
Old 09-05-2019, 12:37 PM   #3
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Would be nice to include the torque specs with these bolt part numbers too as people are always looking for the torque spec. Just a thought while the list is still small and easier to update/add info.
Nick S is offline   Reply With Quote
Old 09-05-2019, 09:52 PM   #4
JCunningham
Drives: 2017 2SS M6
YES THANK YOU
Old 09-06-2019, 08:01 AM   #5
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
J6M (SS 1LE) front caliper bolts are TTA. They can be reused per the service manual, I've done it. Follow the procedure in the manual. Although if you do a lot of caliper removals I would replace them every so often since they are not that expensive, especially if tracking a lot which I do.
J6M (SS 1LE) front caliper bolts = 11570092
Torque first pass to 150N-m or 111 lb-ft
Second pass 15-30 degrees
carguy55 is offline   Reply With Quote
Old 09-20-2019, 11:36 PM   #6
JCunningham
Drives: 2017 2SS M6
the dealer gave me 11611085 for the fronts for a 17 ZL1
Old 03-21-2020, 02:36 PM   #7
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
2020 ZL1
Front Caliper Bolt GM 11570092, 111lb-ft then 15-30 degrees
Rear Caliper Bolt GM 11570091, 92lb-ft
For both clean threads, use GM 89021297 threadlocker (red)
h018871 is offline   Reply With Quote
