Old 04-14-2020, 01:09 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Goodridge zl1 brake line not right is a easy fix.
the front pass side (RF) The bracket that bolts it to the strut is off 90deg. is that normal or did i get a bad line? i had to use a zip tie. I dont like that at all. edited title. they twist
Old 04-14-2020, 11:30 AM   #2
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
On my 5th gen Goodrich lines, the mounts weren’t molded into the hoses. I could rotate and slide them. They were tight, but movable
6th gen like that?
h018871 is offline   Reply With Quote
Old 04-14-2020, 01:15 PM   #3
JCunningham
Drives: 2017 2SS M6
they were pretty tight. I did try to move it but not very hard
Old 04-14-2020, 06:03 PM   #4
h018871
Geoff
h018871's Avatar
Yeah, it took quite a bit of twist at first then they moved easier. I hope it works for you, much better than a zip tie
Old 04-18-2020, 05:04 PM   #5
JCunningham
Drives: 2017 2SS M6
i guess i didnt try to hard. it twisted into place no problem. thanks
