04-12-2020, 01:09 AM | #1 |
Drives: 2017 2SS M6 Join Date: Jun 2013
wtb a shifter detent tr6060 or t56
i want to get one to try and put a lighter spring in it for the hurst shifter. something better then the anti venom mod.
04-12-2020, 07:17 AM | #2 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
It might be worth giving Tick a call - if anyone knew anything about it, they might.
You could take it apart, cut a coil or two off, stretch it out to about the same length and that would soften it up also.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
04-12-2020, 07:40 AM | #3 |
How do u get it apart
04-12-2020, 10:22 AM | #4 |
cut it. putting it back together id have to figure out.
04-12-2020, 10:28 AM | #5 |
Oh man. Interesting. Wonder if the top where the spring seats can be drilled out and then threaded so we can drop the modded spring in there and thread on a cap or weld it?
04-12-2020, 11:21 AM | #6 |
I bet it’s just pressed in and lock-tited. Maybe a heat and a screwdriver?
Orange Krush II
04-12-2020, 10:39 PM | #7 |
Drives: 2017 SS 6sp Join Date: Jun 2014
whats wrong with adding washers?
04-12-2020, 10:48 PM | #8 |
the stick flops around and makes it harder to find gears. Im down to 1 thin dorman copper washer and you can hear it tapping the ball bearing a idle. the shifter needs a little resistance on it. with the any washers its not touching the shifter so it will just flop around . With the 1 washer 1-4 feel ok but 5th feels like your putting it in reverse and its harder to find because the resistance is so much more. if there were no washers and the detent had a weaker spring all gears would feel the same.
