Old 03-19-2020, 12:51 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
rear rotor splash shield. ss and ZL1
im putting ZL1 brakes on my SS. back when i got the brakes i bought the splash shields that said ZL1 only. well the ones i got are the same ones that are on the SS and when you look them up know they show they fit both. they are quite a bit smaller than the rear rotors on the ZL1. Do yours look too small for you zl1 rotors?
Old 03-20-2020, 01:06 AM   #2
JCunningham
Drives: 2017 2SS M6
are all the ZL1s like this?
Old 03-20-2020, 01:37 PM   #3
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Idk, but I wouldn't be worried about it. I took a cutoff wheel to my rear splash shields and only left them where the bushings are for a heat shield. The more brake cooling the better on track.
TheRealJA105 is offline   Reply With Quote
