03-13-2020, 11:36 PM | #1 |
Drives: 2017 2SS M6 Join Date: Jun 2013
wheel drive shaft washer
in the factory manual it says to replace the wheel drive shaft washer. The washer behind the wheel bearing on the CV shafts. The section is not broken up as in SS or ZL1. I can only find the washer for the ZL1 and to get one for the SS you have to buy a boot kit $75 each. im not doing that. I thought i read something on it but the search is not working. im anial and doing ZL1 brakes so im even replacing the rear splash shields. anyone know the part number or if the ZL1 is for both. stores say ZL1 only.
03-19-2020, 08:23 PM | #2 |
there wasnt one on it.
