10-04-2022, 11:29 AM | #1 |
Drives: 2023 Camaro ZL1 Join Date: Sep 2022
TONY MAMO TB
Hello. I was wondering if anyone has the tony mamo throttle body and if it is safe to install without any tuning required. Does it actually work? is there really a difference between the stock tb.
KINGPIN
10-04-2022, 02:08 PM | #2 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
As mentioned in your other post, I have one on a stock tune. I did before/after tests with the only change being the Mamo ver 2 ported TB (I added a K&N intake after doing the before/after tests). I used the onboard timer and measured multiple 60-100 time splits. Stock, the top two times were 3.7 and 3.8 sec with a 1,900' DA (and I had multiple 3.8 sec splits so it was consistent). With only the ported TB the top two times dropped to 3.5 and 3.6 sec. with a 1,100' DA. The DAs were pretty close but corrected for DA that equates to ~3.7 sec avg vs. ~3.5 sec avg. Definitely an improvement. This would translate to about 0.3-0.4 sec improvement in the 60-130 time. I did the "after" tests several days after installing the TB (maybe a week), so it had some miles on it. I could not replicate the 3.5 sec. split again but was able to achieve multiple 3.6 sec splits. This was all on 91 octane.
You can't feel the difference in acceleration "seat of the pants". Adding ~15 hp when you start with 650 hp isn't enough to feel, but it is measurably quicker. Full disclosure, with the first TB Tony sent me, my car would not idle nor run, I sent it back and he replaced it with another one, and it has run perfectly since the beginning of this year. I believe the first one was too aggressive of a port job for the stock tune. There was definitely more material removed when comparing the two TBs, and at idle, was letting too much air through. And FYI, I did the tests again with the K&N carbon fiber intake and the top 3 average times improved slightly over just the Mamo ported TB, corrected for DA it was 0.05 sec faster over three runs (not much, but that equates to about a tenth in the 60-130 mph split). Same DA and fuel. The intake may be only slightly faster than the stock box, but it looks and sounds MUCH better.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
10-04-2022, 03:15 PM | #3 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
It's probably one of the cheapest, and worthwhile upgrades you can do to our cars. There are 100s of threads already about Mamo throttle bodies, I have the V2 and was able to tell a difference in throttle response etc between his and stock. Pull the trigger and get one. His customer service is also top notch!
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
10-04-2022, 05:32 PM | #4 |
Drives: 2018 ZLE M6, '15 CLS 63s AMG Join Date: Jun 2017
I have a new V2 in the box never used that you can have for free, I went with a 103mm. My car is still in the shop for another 4-5 weeks maybe if I spread some good karma, it will come back to me sooner Send a PM and I'll ship it out to you.
2018 ZLE M6: Heads/Cam, Kong Stage X Port, Katech 103MM Throttle Body, Meth, Built by CSP, Flowmaster American Thunder, NITTO 345/30R19 NT555RII 811whp
2015 CLS 63s AMG MCT7: NGK plugs,BMC filters/spacers,Labworxs Development tune 644/766 (11.22 @ 127 1/4) |
10-04-2022, 05:55 PM | #5 | |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
10-04-2022, 05:57 PM | #6 |
ZL1 Driver
Have you had any issues with your oil pump with all your mod's? It looks like you have a 2018 ZL1. Mine is a 2017 and people have said we are in the caution block. BTW I'm not far from Valley Forge. I'm in York.
10-04-2022, 06:17 PM | #7 | |
My suggestion is if you're planning on keeping the car do yours preemptively, I wish I followed Andrew's advice and did H/C last year when it was in the shop like they suggested, I went with meth because of the cost. I won't make that mistake again; I'll leave it to the professionals from now on.
10-04-2022, 06:23 PM | #8 | |
ZL1 Driver
10-04-2022, 06:34 PM | #9 |
I thought only Nick Williams made throttle bodies
'20 ZL1 1LE A10,
10-04-2022, 06:46 PM | #10 | |
10-04-2022, 06:49 PM | #11 |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
So what is the order of quality here between all the throttle bodies?
Tony Mamo Soler Nick Williams Those are the three I know of, but I always hear stories about, "oh, well it worked for the first few weeks or two months and it changed the way the car run in favor of better, but eventually the PCM learned it's new parameters and reverted back to the same way it used to run."
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
10-04-2022, 06:54 PM | #12 | |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
10-04-2022, 09:27 PM | #13 | |
Did that feeling like the throttle is still engaged while coming to a stop go away as well after the TB replacement? I know many people have noticed that and don't like the issue. I have definitely noticed it on mine and I hate it as well, but it doesn't seem to be a tuning issue.
737 HP/ 779 TQ |
10-04-2022, 10:03 PM | #14 | |
Tuning does also help the issue that you are describing. I don’t think it can be completely eliminated on this platform but I know it can be improved. Maybe some of the tuning gurus can comment on that. I’m no tuner, so I can’t explain why it does it or how to fix it.
