Old 12-01-2018, 01:41 PM   #1
mgb
mgb's Avatar
Drives: 2010 ABM 2SS - 2012 ZL1
Trickle Charge
Can I hook up my trickle charge under the hood or do I have to go to the battery?
mgb is offline   Reply With Quote
Old 12-01-2018, 02:48 PM   #2
bowtie67
Emerald Coast Camaros
bowtie67's Avatar
Drives: 2013 ZL1
you can hook it up either way
2013 Camaro ZL1 IOM M6
2006 Trailblazer SS (grocery getter)
2007 Cobalt SS/SC
2002 Camaro 35th Anniv. Conv.
1991 Camaro Z28 350 Auto
1967 Camaro SS396, M4 Conv. Highly Modified
1967 Camaro SS396, M4 Coupe
2008 Buell 1125R
bowtie67 is offline   Reply With Quote
Old 12-01-2018, 03:18 PM   #3
2013ZL1FUN
2013ZL1FUN's Avatar
Drives: 2013 ZL1 Convertible A6 BRM
I use a float charger. It pulses a charge intermittently, as needed to keep battery fully charged.
2013 ZL1 CONVERTIBLE BRM A6
OHIO
2013ZL1FUN is offline   Reply With Quote
Old 12-01-2018, 05:50 PM   #4
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
I attach mine under the hood
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
SecondZ28 is offline   Reply With Quote
Old 12-02-2018, 08:34 AM   #5
mgb
mgb's Avatar
Can I hook the positive to (+) post under the hood and then just place the ground on any ground under the hood? I can't get to the negative post due to the ice box that's been added.
Old 12-03-2018, 02:11 PM   #6
HammerZL1
HammerZL1's Avatar
Drives: 2010 Camaro SS
Talking
Should work fine, that's what I do.
John & Natalie Boyd
2010 Camaro 2SS/RS Silver Ice Met L99/Auto
Build Date 6/29/2009
HammerZL1 is offline   Reply With Quote
Old 12-04-2018, 12:28 AM   #7
StreetRage320
Those who need me got me
StreetRage320's Avatar
Drives: 2022 ZL1 A10
Would work either way I currently have a trickle charger hooked up permanently to my battery. I tuck it underneath the carpet in back when not in use.
StreetRage320 is offline   Reply With Quote
Old 12-04-2018, 05:51 AM   #8
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
I use the positive post under the hood along with the ground stud, I have done that every year since I got it in 2012
Happy_Dan is offline   Reply With Quote
Old 12-28-2018, 12:41 PM   #9
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Can you guys post some pics of your set ups.
Need to add a Trickle charger and not sure if going through the rear truck area with the battery or just leave the hood pooped open in front is the way to go...
Any suggestions on which charger to buy? I'm guessing they all work the same?
Mods:
Old 12-28-2018, 12:44 PM   #10
HammerZL1
HammerZL1's Avatar
Talking
I use a Battery Tender Jr. and hook it up under the hood. Works great.
John & Natalie Boyd
Old 12-28-2018, 12:52 PM   #11
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Thx
Need to figure something out... Only fire it up on weekends and it's drained a few times and I've gotten service codes popped up do to starting with a low battery....
Mods:
Old 12-28-2018, 12:54 PM   #12
derieu
Engineer
derieu's Avatar
Drives: 2014 Camaro 2SS RS 1LE
https://www.amazon.com/Optima-Digita.../dp/B00DHGPVKI
you want a battery tender, not a trickle charger. I use this one, its phenomenal. It automatically determines when it needs to be charging or maintaining the battery. It charges the battery to full and then maintains it at that level. Also has a start/jump feature for extra amperage.
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP
-Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing
derieu is offline   Reply With Quote
Old 12-28-2018, 01:20 PM   #13
HammerZL1
HammerZL1's Avatar
Here's all you need to maintain your battery. You won't be able to charge a dead one though, you'll need a charger for that.
https://www.amazon.com/Battery-Tende...ender+jr&psc=1
John & Natalie Boyd
Old 12-28-2018, 02:10 PM   #14
batman53201
Account not blocked
batman53201's Avatar
Drives: The Batmobile
here is what I use. works great. I ended up buying 8 of them. yeah, I got lots of batteries
https://www.northerntool.com/shop/to...9669_200589669
batman53201 is offline   Reply With Quote
