Vararam
Old 03-09-2014, 01:22 PM   #85
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
I disagree with those that say the strut tower brace does nothing. I installed the stock GM brace last week and it definitely feels more solid in the front end. Steering is more controlled, its not a major difference, but its noticeable for me.
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph
Thunderhill 2:22.242
Cuda7050 is offline   Reply With Quote
Old 03-09-2014, 11:22 PM   #86
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Anyone with a BMR brace running a ECS/novi supercharger? Just wonder which will work....I like the STB016 4- point but don't know if it will clear air filter on novi.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 03-09-2014, 11:32 PM   #87
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
+1
Mods:
Old 03-11-2014, 06:35 PM   #88
United_727
Parts Guru Extraordinair.
United_727's Avatar
Drives: '02 SS 'Vert M6
Originally Posted by 130R View Post
Early 11's… And no, I don't know the cutoff date. You either have holes or you don't...
There is an '11 in the shop now,built 12-14-10 that has the holes. So....
Please check out my other hobby ; http://jetphotos.net/showphotos.php?userid=1008
United_727 is offline   Reply With Quote
Old 03-11-2014, 07:35 PM   #89
130R
Drives: SS
Do a search. There are 11's without the holes, so...
130R is offline   Reply With Quote
Old 03-12-2014, 02:46 AM   #90
thkfast
thkfast's Avatar
Drives: '14 Red 2SS/RS/LS3
GMPartsDirect.com Part# 23120485 $111.30 plus $26.71 processing & handling = $138.01
thkfast is offline   Reply With Quote
Old 03-12-2014, 04:59 AM   #91
brackywilles
brackywilles's Avatar
Drives: Its beautiful with red color
I think for model, before 2013 all have drill holes. The 2013 ones would be happy cause they get the superior one.
brackywilles is offline   Reply With Quote
Old 03-12-2014, 08:41 AM   #92
United_727
United_727's Avatar
I was showing that an '11 built on this date (at least and forward) has the holes.
Old 03-12-2014, 03:31 PM   #93
wally mayfield
wally mayfield's Avatar
Drives: 2013 2SS 6M
For 130R:
http://channel.nationalgeographic.com/videos/camaro/
Strut tower brace(GM), CAI, Blade Spoiler, ZL1 wheels and tires, Heritage grill, Dual mode exhaust, and thats it, no more..except for the lowering springs..Ok Hotchkis springs were delivered today, thats it..
wally mayfield is offline   Reply With Quote
Old 03-15-2014, 12:19 PM   #94
Camarosrock
Drives: None anymore, sadly
'10's & early 11's don't have the holes. If you don't see 3 threaded, unused holes on each tower, you need to make them. You'll also need adapters/spacers as you also won't have the reliefs in the towers for the brace.
I had a look - no holes, sadly. Thanks for the help.
Camarosrock is offline   Reply With Quote
Old 03-17-2014, 11:21 PM   #95
Bear
Bear's Avatar
Drives: 2015 Green Flash 2SS M6
Why this http://gmpartsdirect.com/results.cfm...ber=pkcamarobr
and This http://www.gmpartsdirect.com/results...umber=23120485
on same website with different pricing? What am I missing?
Back in the Game.
Bear is offline   Reply With Quote
Old 03-30-2014, 05:29 PM   #96
Ipockalypse
Ipockalypse's Avatar
Drives: 2017 ZL1 M6
Is BMR planning to make the four point strut tower brace (STB016) to fit a 2013 Camaro? That's the one I'm most interested in but the current STB016 definitely doesn't fit.
Ipockalypse is offline   Reply With Quote
Old 03-30-2014, 05:37 PM   #97
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
For those with the Pfadt brace, I've started laying mine out for installation and it appears that the rear bolt on the passenger side goes through the hood support bracket. Is this correct or did I lay it out wrong. Pictures of this area would be greatly appreciated.
2010 2SS
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 04-04-2014, 01:46 PM   #98
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
I figured out the above problem You drill straight through the welded connection.
Installed this beast last night. Fairly straight forward install. Rivnuts suck if you don't have a tool to install them with (I used a bolt and washer).
It may be purely in my head, but the front end feels a lot more solid. This is true for even going straight.
