12-20-2018, 08:41 PM | #15 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
I run 2" LT's with modified Vibrant resonators in place of the cats along with the stock mufflers and a mild to wild switch so I can run it closed or stock. Sounds great with no rasp or drone. I like the flexibility to switch so it provides a nice option.
12-20-2018, 11:23 PM | #16 |
Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
Here you go....I ran this for a while till I did j-pipes...
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
12-27-2018, 02:38 PM | #17 |
Drives: 2013 ZL1 M6 Join Date: Sep 2016
I run Noweeds cutouts and no cats with LT headers. I love the way it sounds.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP 630.35 RWTQ |
12-27-2018, 02:42 PM | #18 |
Instagram: Sangstah
I personally think the Borla S type is too quiet lol, I would just go back to stock exhaust maybe?
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
12-28-2018, 09:33 AM | #19 |
I think the only reason I will eventually change my exhaust is to go to 3" pipe. I would get the Borla S only because if I want it loud I can open the cutouts.
12-28-2018, 12:19 PM | #20 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Modify one of the best OEM exhaust systems and then complaining about it's too loud.... give me a break. You own a ZL1.....
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
01-16-2019, 12:08 PM | #21 |
Snake Eater
Drives: 2012 AGM ZL1 Join Date: Oct 2011
Ew what is this I see wanting to be quiet, but mustangs are screaming down every street in USA.... Also the Borla S type is some of the quietest exhaust and you still have problems...may be time for that Focus you been eyeing lol I'm messing
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ Follow me on instagram: http://www.instagram.com/snkeatr/ |
01-16-2019, 07:25 PM | #22 |
Drives: 2012 ZL1 Ashen Grey Join Date: Apr 2017
Go CORSA or go home!!!
2012 M6
Kooks 1 7/8, off road pipes , full corsa exhaust ID1300s/ 22% lower / 2.5 upper, JLT CAI, DSX flex fuel, DSX AUX fuel pump. S19 cam Tuned and built by Speed Inc 635/632-93 octane 725/738-E85 |
