04-27-2022, 01:39 PM | #1 |
Drives: 2011 Camaro SS Join Date: Jul 2017
New coilover ride height.
What do you guys think about this ride height? It's pretty much stock ride height. It's a drag oriented suspension and wheel set up. Should i drop it another half inch? Crap 1st pic is rotated wrong. Sorry.
04-27-2022, 03:53 PM | #2 |
Looks almost stock to me. I think it should be a tad lower, like 1 inch??
04-27-2022, 04:52 PM | #3 |
Drives: 2015 Z/22 Join Date: Aug 2015
Going for looks or function? JusticePete suggested not going lower than 26" in the rear (measured from bottom of wheel lip/rim to fender) for the sake of the axles/joints. I lowered mine such that the top of the tire was nearly flush with the bottom of the fender (about 25 5/8"), but I'm going to raise it in the near future to 26" for practical reasons.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
04-27-2022, 06:18 PM | #4 |
I want it to look better but can still hook. It just looks like a 4x4 to me. I'm going to measure it like you mentioned and see where it sits.
04-27-2022, 07:39 PM | #5 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Drop it
04-27-2022, 10:22 PM | #6 |
What tires are you running up front & wheel width. The rear looks good but the fronts look a little skinny stretched on a wide wheel in the 1st pic.
04-28-2022, 01:35 AM | #7 |
28×4.5×18 M&H on a 18x5 rim. The recommended rim width was 4 1/2 but I don't think the front rims come in a 4.5 width?
04-28-2022, 05:03 AM | #8 |
That is a common setup. I think it looks good, maybe a tad lower as already posted.
04-29-2022, 10:31 AM | #9 |
Instagram: Mr2Hard2See
Drives: 2011 2SS/ RS Join Date: Apr 2018
Drop it down more
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242 BTR dual springs pushrods lifters retainers etc Che bronze trunnion Ls3 timing/valley cover Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers |
05-03-2022, 06:21 AM | #10 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
Drop it lower
