Old 02-09-2022, 03:13 PM   #1
taylorforschool@gmail.com
PKG4U
taylorforschool@gmail.com's Avatar
Drives: 2018 ZL1
ZL1 (non-1LE) wheel fitment
I’m trying to find reasonably affordable 19x11 front 19x12 rear setup for my 2018 ZL1. Besides the 1LE OEM wheels on AM for $3500 which I am considering. Are there any 19in wheel recommendations in this range? Also do I need spacers or will I have fitment issues if I go with these. Thanks all tire wheel fitment advice appreciated
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S
Mods after Warranty “Imma keep it stock”
taylorforschool@gmail.com is offline   Reply With Quote
Old 02-09-2022, 03:25 PM   #2
PJS57
Drives: 2023 Cadillac CT4
Check out Apex wheels: https://www.apexraceparts.com/shop-b...en-camaro.html
My dad got a set of 19 x 10s for his ZL1 for running all season BFG's and they are very high quality wheels. They have them in the sizes you're looking for too, and cheaper than the ZLE OEM wheels..
PJS57 is offline   Reply With Quote
Old 02-09-2022, 03:37 PM   #3
HoodCheck
HoodCheck's Avatar
Drives: 2018 ZLE (M6/hyper blue)
5mm spacers up front...or you need to cut a notch out of your strut.
https://www.camaro6.com/forums/showt...u---Tngm4Jk6Hs
If you don't do either, you'll grind the inside of your wheels on a sharp turn. I made the mistake of trying to drive my old '17 ZL1 (regular) for a few days without them...first sharp turn into my driveway, scraped the inside of the wheel.
I don't track my car, so there was nothing special done to the alignment or anything either...it was fine if not turning sharp, but thats pretty much unavoidable.
Current: 2018 ZLE (M6/hyper blue)
Former: 2014 Z/28 (red hot); 2017 ZL1 (auto/white); 2015 Z/28 (black); 2016 2SS (auto/hyper blue); 2012 2SS (45th anniversary/auto); 1994 Firehawk (auto/dark green); 2005 GTO (M6/blue on blue); 1999 Camaro SS (M6/pewter); 1994 Z/28 (auto/blue); 1991 Firebird (auto/red); 1988 IROC (auto/copper metallic); 1983 Camaro (auto/blue); 1981 Firebird (auto/maroon/350 Olds swap)....the list goes on...
HoodCheck is offline   Reply With Quote
Old 02-09-2022, 06:49 PM   #4
Blueclyde
Drives: 2023 ZLE
I installed the ZLE wheels and tires on my standard ZL1. I do a lot of tracking. They fit with stock camber but I did grind the struts to allow for negative camber required for the track. I found a used set of wheel in good shape, and they had brand new Goodyear R’s.
If I hadn’t found that deal I 100% would have gone with Apex. They have a fantastic figment guide on their website and they have a great product. That’s a great way to go. Lots of folks run their wheels.
Blueclyde is offline   Reply With Quote
Old 02-09-2022, 09:17 PM   #5
PKG4U
Drives: 2018 ZL1
Yeah I’ve been looking more and more at apex. Just wanted to make sure. Appreciate the feedback.
Old 02-10-2022, 12:20 PM   #6
MikeEM1
MikeEM1's Avatar
Drives: Tracks: 18' ZL1 1LE
Apex has a group deal right now for their SM10 model and you can select ZL1 1LE sizes. Should be around $1,800 after discount is applied.
Just know you'll probably have to wait a couple months to get them after the group buy closes.
https://www.gangup.com/apex/apex-sm10-q1-2022.html
18' ZL1 1LE Red Hot track toy
Castrol SRF
Ported TB/Rotofab dry intake
AWE Track w/PLP
APR GTC300 wing / Singular Endplates
ASC Splitter / PA tunnels
MFR Engineering Custom Diffuser
Race Louvers Fender Vents
APEX SM10 & ARC8
For sale: 2018 OEM ZL1 1LE Wing
12' Nissan GT-R SOLD
MikeEM1 is offline   Reply With Quote
Old 02-10-2022, 02:31 PM   #7
TXCSSU
Drives: 2022 ZL1 M6/Nissan Leaf
Their website indicates that no spacers are needed for the ET-41s, just the ET-35s. Is that correct?
TXCSSU is offline   Reply With Quote
Old 02-10-2022, 08:25 PM   #8
Blueclyde
Drives: 2023 ZLE
I think the spacer is going to depend on how much negative camber you plan to run. If you have mag ride and plan to run negative camber you will need clearance.
