11-14-2022, 06:49 PM | #1 |
Drives: 2023 Camaro 2SS 1LE Join Date: Sep 2015
ZL1 Addons Lift Pads
Hi Guys, I'm looking into getting ZL1 Addons lift pads, I already had a close call tire shops jack almost slipped off and caused some cosmetic damage under the car. Question is has anyone ever experienced them coming loose? also whats the difference between the stealth and regular ones? what should i get?
11-14-2022, 06:58 PM | #2 |
Drives: like an old lady Join Date: Jun 2012
mine have been on since 2019. 35k+ miles, no issues. i often forget they're on there.
2016+ camaro: everyone’s first car
11-14-2022, 07:49 PM | #3 |
+1! very easy install. Was able to get them installed in maybe 5 mins during storage I do forget they are installed just like S346k mentioned lol. Usually comes to mind when I take the car into the shop and hound on my advisor to let the techs know to use those pads
11-14-2022, 08:09 PM | #4 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
I've had mine on for about 2 years (or only 4k miles). Car is mostly a track car. I did use blue loctite on the threads but never had an issue.
11-14-2022, 10:00 PM | #5 |
Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
Agree 100%. Blue loctite on mine as well. Those tiny set screws provided tend not to grab well IMO. Going on three years now with no issues.
11-14-2022, 10:02 PM | #6 |
Guys should I order the regular ones or stealth. The stealth ones look like there wider.
11-15-2022, 06:06 AM | #7 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Get the stealth pads, as they do not protrude as much below the frame. They will not come loose, as you have set screws to tighten. (It comes with the set screw tool as well) Great add on to the car.
11-15-2022, 10:38 AM | #8 |
Electrical Engineer
Drives: 2023 1SS A10 Black Join Date: Apr 2022
Definitely needed. Dealer damaged my pinch welds during PDI. They work well, and I want them below the side molding to protect it as well. I used blue loctite on the screw threads. They aren't going anywhere.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
11-15-2022, 11:50 AM | #9 |
I'm going to order the stealth in candy red. They are out of the stock but they should have them in by end of this week. I'll hold off on my oil change until there installed. Thank you everyone for helping me out.
11-15-2022, 12:07 PM | #10 | |
Electrical Engineer
11-15-2022, 12:35 PM | #11 |
Got it. Ill grab that too. should I install the front ones closest to the tire? theres 2 lift points in the front.
11-15-2022, 12:45 PM | #12 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
Or purchase two more lift pads and install them in the two additional lift positions.
24 2SS 1LE, Riptide Blue, A10, PDR. Picked up 11/5/23, 560 miles.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
11-15-2022, 01:09 PM | #13 |
Electrical Engineer
I considered that but I didn't want to confuse any shop into thinking they could use the middle lift points instead of front lift points, I wouldn't want that much weight hanging off the front.
11-15-2022, 01:10 PM | #14 | |
Electrical Engineer
The jack pad (where you lift) is more towards the middle.
