dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 01-22-2018, 08:59 PM   #1
JS1
Drives: Black 2013 2SS RS 1LE
ZL1 brake kit for track days
Anyone swapped to a ZL1 brake kit (front and rear) on the SS or 1LE for better braking at track days? I'm thinking of doing a big brake kit or just swapping to ZL1 rotors, calipers and pads. I know the rears are the same, mostly concerned with the front. I don't want to swap, I want an upgrade. I already have SS lines for clutch and brakes, brake ducts, SRF fluid, good tires, separate PS reservoir suspension upgrades...a good number of track days just trying to see what makes sense next. Thanks in advance. Will the 2 piece rotor and extra size make it worthwhile on track? Mostly at VIR.
JS1 is offline   Reply With Quote
Old 01-23-2018, 07:52 AM   #2
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
I'm intending on the swap early this year. Several have done it already. My goal is better heat management, and a 2 piece with more surface area and larger calipers will certainly help.
Hopefully some others will chime in with actual feedback. Search around a bit you'll find some posts on it.
bkevind is offline   Reply With Quote
Old 01-23-2018, 08:23 AM   #3
Yellow6thGen
18 ZL1 A10 Convertible
Yellow6thGen's Avatar
Drives: White ZL1 Convertible
I have a set just saying ... I bought a ZL1 sold my SS and never installed them... they have 17 miles on them from 17 ZL1 in perfect condition.. I’m including the oem pads too and are included. I have them boxed and ready to go.
2018 ZL1 Convertible A10 @ Kooks R&D.
Yellow6thGen is offline   Reply With Quote
Old 01-23-2018, 09:41 AM   #4
Synner
Drives: cars
It's a definite upgrade but still needs brake ducts. These fat pigs like to fade and the stickier your tires the faster they do. So it depends on how track focused you want to get. There are better BBK options but cost benefit goes down, the ZL1 setup is an excellent option for a reasonable budget. When you add up the parts with a real track pad you're looking at 1800ish versus 5000ish. That difference is a lot of pads and caliper rebuilds.
Synner is offline   Reply With Quote
Old 01-23-2018, 04:52 PM   #5
JS1
How much for your set?
Old 01-23-2018, 04:55 PM   #6
JS1
Thanks for the feedback. The stock brakes are fine but I think I can do better for a little more cost and stay well below the BBK prices. I'm trying to stick with street tires so things don't get out of hand. It's enough fun at VIR without moving to slicks, BBK, cage, etc...So far I'm managing to keep everything cool enough.
Old 02-02-2018, 02:04 PM   #7
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
I have switched the front works great
If you all ready have the rear brembos they are the same size on the Ss as the zl1 on the rear
I have been using the racing brake 2 pice rotor and it has held up fine
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 02-02-2018, 02:22 PM   #8
bkevind
bkevind's Avatar
Just ordered ZL1/CTS-V front rotors, calipers, SS lines and 2x caliper hw kits from Amazon.
Total for that was $1349 before taxes, free shipping.
Old 02-22-2018, 01:43 AM   #9
hammdo
'It's an experiment'
hammdo's Avatar
ZL1 setup on mine SS (stainless) lines too with fluid upgrade...
Worth it!
-Don
747 RWHP 794 RWTQ
Old 02-22-2018, 12:00 PM   #10
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
I have the CTS-V 6 pistons, which are the same as the ZL1's but cheaper per other threads. SS rears are same as CTS-V/ZL1. Fronts are a definite improvement on the track. You will feel more in control in the braking zones.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 02-22-2018, 01:32 PM   #11
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
If you rebuild try to get a set of vented pistons from the Z06 Steel rotor car they are supposed to reduce heat by 80 F or C I cant remember.
Orange Krush II
Old 02-23-2018, 10:58 AM   #12
tylerio
EXTREMZ
tylerio's Avatar
Drives: 2015 Z/28 #891, 2012 2SS 45th Anni
I did the fronts on my 2012 SS. Zl1 two-piece rotors, CTS-V Brembo six-piston calipers, SS brake lines, track pads, Motul 660 fluid. Noticeably better braking. I'm on sticky tires, so heat builds towards end of lap sessions. Need to put in ducts. Still, much better on the track than before.
ARH long tube headers, no cats
Comp Cams stage 2 custom grind
Ported throttle body
JPSS Oil cooler
JPSS SAI plates
JPSS Rear sway bar
Forza Continenti exhaust controller
ZL1 Add-ons wickerbill
Brey-Krause Harness bar
Schroth 4 pt. ASM harnesses
Auto-blip
tylerio is offline   Reply With Quote
Old 03-02-2018, 05:51 PM   #13
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
OP
the 6 piston brakes don't stop any "better", they just resist fade longer. Z28 inner wheel wells and ducts really help
look here: http://www.camaro5.com/forums/showthread.php?t=418879
also if you go with the Corvette calipers, they are already red and match your 1LE rears.
LF: AC Delco 172-2669, RF: AC Delco 172-2670, they seem to be cheapest on Amazon
h018871 is offline   Reply With Quote
Old 03-09-2018, 03:08 PM   #14
12blkgrayRS
12blkgrayRS's Avatar
Drives: 2012 Camaro RS 2LT 6spd man
What are you asking for this?
12blkgrayRS is offline   Reply With Quote
track days, vir, zl1 brake kit
