09-09-2018, 08:21 PM | #127 | |
Pitt Race (Formerly BeaveRun), North Track
2014 SS 1LE, M6 1:03.83 Z/28 suspension, ZO6 front brakes w/ Raybestos ST43, 405 SAE RWHP 305/30-19 Goodyear F1 SuperCar 3R 79* ambient, overcast/sprinkles, dry track https://youtu.be/Mkrcwyxvp2k
11-05-2018, 09:10 AM | #128 |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
Ncm full course dry
2010 camaro ss manual 285/30/19 re-71r 60 * ambient sunny day
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
11-05-2018, 01:13 PM | #129 |
@MrRaZ28
Have 2 entries for 1 track I don't see on there, and 1 shorter version of a track.
Eagles Canyon Raceway Full, CCW, 2014 Z/28, M6, 2:11.26, Conti ExtremeContact Sport 325/30R19 squared, Dry MSR Cresson 1.7, CCW, 2014 Z/28, M6. 1:30.73, Conti ExtremeContact Sport 325/30R19 squared, Dry |
11-07-2018, 07:11 PM | #130 |
Door ding magnet
Summit Point main
2010 Camaro SS Auto 1:31.9 on Nov 4th 2018 Continental ExtremeContact Sport, stock size Dry, approximately 50 degrees https://youtu.be/6fYwyy6-pZI
"When you're racing, it's life. Anything that happens before or after is just waiting." |
01-21-2019, 06:29 PM | #131 |
Drives: 2013 camaro zl1 aka the Reaper Join Date: Apr 2018
unable to post video and pics of track times due to being on deployment at the moment but..
NCCAR (north Carolina center for automotive research) CW 1:41.956 285/35r20, 315/30r20 toyo r888r dry |
01-21-2019, 06:30 PM | #132 |
^^ top speed that day was 146mph If I remember correctly
03-13-2019, 07:54 PM | #133 | |
Drives: 2010 2SS/RS & 2007 2500HD D-Max Join Date: Dec 2014
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, JRI Coilovers built by Ult_Performance w/hypercoils, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast |
04-11-2019, 02:41 AM | #134 |
#551
Drives: 2011 Camaro SS Join Date: Apr 2010
Vir Full
2011 SS 295/35/19 315/35/19 dry 2:08.21 Lime Rock Same specs , dry 1:01.05 NJMP Lighting Same specs , dry 1:14.21 Njmp t-bolt , no chicane Same specs , dry 1:33.56 Watkins glen full Same specs , dry 2:11.19 Can post screenshots if needed , just lazy
05-13-2019, 03:23 PM | #135 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Cresson 3.1ccw
13 1LE , manual, F1G3, 285/30R20, dry 2:16.72
07-22-2019, 11:58 PM | #136 |
Emerald Coast Camaros
Drives: 2013 2SS/RS L99 Join Date: Dec 2013
Same car , same setup July 11, 2019 with RE71s instead of MPSS and ran consistent times of 2:31 and 2:32 which I am pleased with. Low on HP with stock L99 auto but have found weak link on car now. Auto trans can’t take the abuse and needs bigger trans cooler. And I need better brakes. I like to dive in hard and be aggressive but can’t get the same braking feedback each time. I stand on brakes and at times still turn in too fast. Stock 4 pots need to go by next year for sure.
07-23-2019, 05:20 AM | #137 |
Do the Z06 vented 6 piston and good air ducts an think you'll be good.
Orange Krush II
07-23-2019, 07:55 AM | #138 | |
corner barstool sitter
Norm
08-01-2019, 10:35 PM | #139 |
Pitt Race (Formerly BeaveRun), Full Course
2014 SS 1LE, M6 1:55.75 Z/28 suspension with DSE Speed Kit 1, ZO6 front brakes w/ Raybestos ST43, 442 RWHP 305/30-19 Goodyear F1 SuperCar 3R 84* ambient, partly cloudy, dry https://youtu.be/sJ8Yk898ckE
09-01-2019, 07:46 AM | #140 |
Drives: 14' Red Z/28 #336 Join Date: Mar 2016
Putman Park Road Coarse 8/24/19
Ran there with Indy SCCA Time Trials event 2014 Z/28 on the OE Pirellis Trofao's Best lap of day 120.555 enough for class win. I looked through here some but did not see were anyone else has ran there and would like to see some lap times, it was our first time there. |
