dave@hennessey
Old 04-26-2017, 10:01 PM   #1
TEXnZL1
TEXnZL1's Avatar
Drives: 2014 Camaro ZL1
Deploying again. Storage wheel options
My storage unit doesn't have enough room for me to utilize a jack to put the car up on jack stands while I'm gone. Would like to grab some wheels off of something at a junkyard and throw them on while it's in storage. I am NOT coming home to flat spots on $350 a piece tires. Let me know if you guys can think of a common chevy car or truck rim that'll fit so I can roll my car into storage without worry. Thanks
2014 ZL1 M6
TEXnZL1 is offline   Reply With Quote
Old 04-27-2017, 01:37 AM   #2
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
If you can get the car in storage unit ... how come you cant jack it up?
Even if space on the sides is limited , should be ablt to get a tiny jack in there... get some
Jack pads and two jacks go up evenly on each side, throw it on smallest stands for the weight , then do the rear
Stay safe...
Sorry i cant awnser your question about wheels
Crash76 is offline   Reply With Quote
Old 04-27-2017, 01:47 AM   #3
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
I've read that over inflating them to 45 pds will stop the flat spots...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 04-27-2017, 06:30 AM   #4
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
Get some of the foam insulation stuff that is used as insulation when building a house. I bought a 4X8 sheet and cut it into 4 sections. One under each wheel and never get flat sports.
Thank you for your service. Prayers for a safe return!
Happy_Dan is offline   Reply With Quote
Old 04-27-2017, 07:48 AM   #5
E. Bryant
Gearhead
E. Bryant's Avatar
Drives: 2012 ZL1
Getting sufficient brake clearance is the biggest hurdle with the wheels. I've seen some cheap 20" OE wheel/tire combos in the classifieds section here, and that's probably your best bet. Unfortunately, the deals kinda come and go, and I'm not sure that this works with the timing of your deployment.
That's a rather interesting idea! I'll give it a shot next winter, sleigh I've yet to have any issue with flat-spotting over the typical Michigan winter storage season. Modern tires are way better than ever with regards to this problem.
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip.
11.193@128.13 in 515' DA
E. Bryant is offline   Reply With Quote
Old 04-27-2017, 07:51 AM   #6
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Or this
http://www.homedepot.com/p/Park-Smar...A&gclsrc=aw.ds
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 04-27-2017, 07:53 AM   #7
ZO6 Bryan
ZO6 Bryan's Avatar
Here are some more.
http://www.jegs.com/i/Race-Ramps/101...FQwRgQodUEgEcQ
Bryan 2018 ZL1 M6
Old 04-27-2017, 08:23 AM   #8
FSTORG5
Fast Orange
FSTORG5's Avatar
Drives: 2012 ZL1
Same here. Been using this for years and 2 cars. Works great, and cheap!
FSTORG5 is offline   Reply With Quote
Old 04-27-2017, 09:10 AM   #9
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
I put my tires at 45 pounds and the tires didn't flat spot. Granted that was for 4-5 months and not a year or two. If I was going o be away for a while, I'd put the car up on short jacks if at all possible but leave the tires inflated to 45 PSI and on the car incase of failure of the stands.
Can'tHave2MuchHP is offline   Reply With Quote
Old 04-27-2017, 12:23 PM   #10
FSTORG5
Fast Orange
FSTORG5's Avatar
Drives: 2012 ZL1
Taking some weight of with jacks for storage is ok, but I don't like leaving the suspension hanging. I've had that cause issues too and older cars.
Old 04-27-2017, 12:36 PM   #11
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
It's not a good ideal for any suspension for long periods of time to hang..
ZMEnow is offline   Reply With Quote
Old 04-28-2017, 03:44 AM   #12
TEXnZL1
TEXnZL1's Avatar
This is a great idea. Can't believe I didn't think of something like this. Thanks a ton.
2014 ZL1 M6
Old 04-28-2017, 03:45 AM   #13
TEXnZL1
TEXnZL1's Avatar
Originally Posted by ZO6 Bryan View Post
I've never seen these! Actually pretty badass. Thanks
Got some great suggestions in here. It's much appreciated guys
2014 ZL1 M6
Old 04-28-2017, 07:01 AM   #14
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Your welcome. Those flat preventers are great too but I am cheap so I use the foam board or whatever you call it.
