Old 07-30-2013, 05:40 PM   #1
christcringle
christcringle's Avatar
Drives: 2010 2SS/2011 Pacecar/2011 LS/ZL1
Send a message via Skype™ to christcringle
ZL1 Carbon fiber hood problem
ZL1 Carbon fiber hood problem!
Do you see this problem before?
Look like the fiber seperate from the clear.
Member ¨'' Club Elite '' #99
christcringle is offline   Reply With Quote
Old 07-30-2013, 08:54 PM   #2
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Yes. This covered under a TSB and will be replaced under warranty if some of the blemishes can't be fixed.
Mine had stress cracks and I got it fixed in a few days and this was at the time that the ECF was on constraint.
G-Oil Guy is offline   Reply With Quote
Old 07-30-2013, 09:27 PM   #3
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
these cars give off some heat!! im sure that's a good part of the problem.
1990 IROC-Z Vert LS
1996 SS Vert LT4
1992 Z28 Z03 T5
1992 Z28 Z03 L98
2018 Sierra Denali 6.2
1997 Z28 Z4C
1995 Z28
Jer4251 is offline   Reply With Quote
Old 07-30-2013, 09:36 PM   #4
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
Take it to a dealership they should replace it no issue.
Laus Deo
charlietuna is offline   Reply With Quote
Old 08-16-2013, 11:40 AM   #5
christcringle
Any one see that before?
Old 08-16-2013, 12:35 PM   #6
FSTORG5
Fast Orange
FSTORG5's Avatar
Drives: 2012 ZL1
I am gonig through this with mine now. The clear coat cracked on the edge of the back vents. The dealer took picutes and sent to GM. Waiting for a reply from them.
I don't have pictures but will try and take some this weekend and post.
FSTORG5 is offline   Reply With Quote
Old 08-16-2013, 04:51 PM   #7
mrmertz
Drives: 2013 ZL1
I had the Exact same problem. At first while it was sitting in the garage I took some spray detailed over the area and it failed to budge. Went across it with my fingernail and that's when it occurred to me I was dealing with a blemish of sorts.
Dealer replaced the entire insert. Almost as if specks of fluid during the truck or rail transport from a vehicle above etched the carbon fiber.
mrmertz is offline   Reply With Quote
Old 08-16-2013, 04:59 PM   #8
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
Those inserts are expensive, what are the long term after warranty runs out prospects?
TrekGTO is offline   Reply With Quote
Old 08-16-2013, 05:42 PM   #9
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
The number of those having problems are only a small percentage of the overall production volumes. I'm sure if there were more this would have been the subject of a recall.
Old 08-16-2013, 11:03 PM   #10
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
if it has fish eyes or folds in the weave it is not eligible for warranty as those are normal with carbon fiber. if you can feel them with your finger then it is delaminating and they will replace it. im on exposed carbon fiber insert number 4 at 26k miles counting the scratched purple hue one that came on the car from the factory
joes407 is offline   Reply With Quote
Old 08-17-2013, 02:15 PM   #11
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
Wow, you had 3 of them with delamination? That's crazy. I am on my second for that issue.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 08-17-2013, 02:29 PM   #12
joes407
joes407's Avatar
actually the one that came on the car was all scratched up upon delivery, the replacement delaminated. then the dealer put the next one on but didn't peel the plastic off until it was installed so when they peeled it it had a foggy haze over the whole thing and a bunch of scratches where they peeled the plastic off and number 4 is sitting at my body shop waiting for me to drop off car
Old 08-17-2013, 03:02 PM   #13
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
There have been a few posts on this carbon fiber topic and I'm just going to throw in my 2 cents. While the carbon fiber clear cover makes it look interesting, it is not nearly as durable as good paint. UV damages the resin and the best protectant is to completely cover it with paint. That is why it costs more to have the carbon fiber exposed.
I want the carbon fiber for weight savings and not vanity. I would rather have it painted because that is more durable and therefore more functional. Like I said, just my 2 cents. I'm wondering if you got close to the end of your warranty if you could get it replaced with a painted one that would last.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 08-17-2013, 06:06 PM   #14
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Man, at this point I would have requested the painted one.
I'm still on #2, #1 for me had stress fractures etc in it.
If this one fades or delaminates I'll just request the painted one if I need #3.
