Roto-Fab
Old 11-03-2015, 04:31 PM   #295
131LE
Drives: 2013 ZL1
Quick question. Will this display fuel pressure?
2013 ZL1
131LE is offline   Reply With Quote
Old 11-03-2015, 04:56 PM   #296
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Yes
Mods:
Old 02-06-2016, 07:48 PM   #297
DCC1464
COTW 5/27/13
DCC1464's Avatar
Drives: '11 S/C SS/RS CGM
Is anyone running dashlogic able to see their fuel pressue (commanded/actual)? I do not get any values when i try and use this, just wondering if anyone else can see values
622RWHP/512FTLBS on 91 octane
2.9l Whipple 4" pulley. Vengance VRSP3 cam. Lots of BMR & AAC. Body work by Gary's Customz. Nic D tuned
My build thread
DCC1464 is offline   Reply With Quote
Old 02-09-2016, 01:41 PM   #298
DCC1464
COTW 5/27/13
DCC1464's Avatar
Bump for fuel pressure question
My build thread
Old 02-10-2016, 12:19 PM   #299
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
mine says 59
-bobby
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 02-10-2016, 12:20 PM   #300
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Is this thing accurate????????
Idle throttle is 18%
Pedal to the floor full, 84%
What's everyone get at full throttle?
-bobby
Old 02-10-2016, 01:41 PM   #301
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 ZL1, 2021 Corvette Convertible
-bobby
The same 84%. It's reading the position of the Throttle Position Sensor, not the pedal.
hawk02 is offline   Reply With Quote
Old 02-10-2016, 04:23 PM   #302
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Ok, Reading the position of the TPS, shouldn't is read 100% if its wide open?
=Bobby
Old 02-10-2016, 04:37 PM   #303
Hocky
Drives: Cts-v2
=Bobby
No, that is normal.
Hocky is offline   Reply With Quote
Old 02-10-2016, 07:33 PM   #304
hawk02
Coupe Newbie
hawk02's Avatar
=Bobby
The way I understand it, GM interprets the SAE TPS PID as the voltage % of 5V. When the throttle is at WOT, the voltage on the TPS sensor measures somewhere around 4.2V which is 84% of 5V. The ECU learns this % as WOT. Logging the ETC or Pedal PIDs will give you 100% at WOT.
Old 02-28-2016, 06:07 PM   #305
FSTORG5
Fast Orange
FSTORG5's Avatar
Drives: 2012 ZL1
I have been searching the forums all day and haven't had any luck. I bought a Dash Logic Controller from Summit this week. Firmware is 1.21. My car is a 2012 ZL1, no NAV.
I had no problems configuring the pages. But I plugged into the car and only get a display example on my radio. Not my pages. Nothing on HUD or DIC.
There were no instructions on in car configuration, but I've read a few on this forum. Like cruise control for NPP control. Setting DIC on the NAV page to display Dash Logic? Where is everyone getting this information?
thanks.
FSTORG5 is offline   Reply With Quote
Old 02-28-2016, 06:26 PM   #306
BearZL1
BearZL1's Avatar
Drives: 2013 ZL1 auto
thanks.
Have you read through the forum at all on palmer performance website for the dash logic? It has been somewhat helpful to me, and I just downloaded the most recent firmware 1.21. Have yet to try it again but I was having similar issues. Make sure it's plugged in tight and it should show in the HUD. Next step is to contact their support team.
BearZL1 is offline   Reply With Quote
Old 02-28-2016, 07:09 PM   #307
camguynj
camguynj's Avatar
thanks.
Palmer made major changes after v1.15 to accommodate the 14'&'15 Mylinks. Not all the features & functions of Dashlogic after v1.15 are compatible with '11-'13 HUDs. PM with your email if you want to try V1.15 ( the script can't be sent via a PM). V1.15 is what I use and have no problems. ps- I've tried every version after v1.15 and no dice.
Old 02-28-2016, 08:02 PM   #308
FSTORG5
Fast Orange
FSTORG5's Avatar
Drives: 2012 ZL1
Thanks camguynj. I sent you a pm.
