Old 12-02-2022, 09:10 AM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
what is your current fuel system setup from injectors to low side?
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 12-02-2022, 11:03 AM   #16
Kerry
Drives: 2019 2SS Camaro
50 gph meth low side with jms booster lt4 inj and high pump low side stays 73
Kerry is offline   Reply With Quote
Old 12-02-2022, 03:40 PM   #17
Katech_Mike
Drives: 2015 Camaro ZL1
Originally Posted by SATINSTEEL1LE View Post
less than 130* if I remember correctly. That might be LT4 max though.
See below.
Correct. 130 degrees is max. Likely it's maxing out the pump causing the drop in rail pressure.
Katech_Mike is offline   Reply With Quote
Old 12-02-2022, 05:14 PM   #18
Kerry
so did some logging with the angle and % at 5.4 idc pw its 122 deg at 27.5% rail pressure is down to average 2500 to 2600, 2900 commanded
What yall think? It has to drop down to 4.9 or 5 to get to 2900. low side steady at 73
Old 12-02-2022, 05:38 PM   #19
SATINSTEEL1LE
Drives: 21 ZL1
as I said before, cam time.
SATINSTEEL1LE is offline   Reply With Quote
Old 12-02-2022, 06:33 PM   #20
KingLT1
KingLT1's Avatar
What AFR? I am surprised the DI system is working that hard with 50gph of meth. Either way you are ok where it's at, just close to the limits is all.
2016 NFG 1SS A8
Old 12-02-2022, 08:26 PM   #21
Kerry
11.5 to 9 there abouts
Old 12-03-2022, 08:24 AM   #22
Kerry
So is their anyway to get a little more out of the high pressure pump. Other than a cam?
Old 12-03-2022, 09:44 AM   #23
SATINSTEEL1LE
Drives: 21 ZL1
I dont know the name maybe katech, but another company makes a bigger bore HPFP you can upgrade to. I think its super expensive. Or equally more expensive would be port injection. Just get the cam.
Old 12-03-2022, 09:45 AM   #24
SATINSTEEL1LE
Drives: 21 ZL1
Its lingenfelter. And its $3k.
https://www.lingenfelter.com/product/L710166914.html
Old 12-03-2022, 10:02 AM   #25
KingLT1
KingLT1's Avatar
Try turning the low side pressure up to 80-82psi. The LT4 stuff at 2900psi likes a lot of low side pressure to help it sustain. You might need to upgrade from a single intank pump with JMS to get there.
That's crazy. They used to be 1500-1700.00. I bought mine for 1550.00 in 2019. I have 3400.00 invested into the LPE BB and XDI +30 injectors(which is still expensive). Glad I bought when I did.
2016 NFG 1SS A8
Old 12-03-2022, 11:21 AM   #26
Kerry
thanks i will try that.
Old 12-04-2022, 08:59 PM   #27
Kerry
So let me make sure im understanding this correctly. the 6 ms is about injection time. having enough time to get the fuel in time for it to work correctly.
If it goes to say 5.5 or so and even though the high pressure is droping some it will try to compensate by keeping the injector open longer keeping things at commanded but getting on the ragged edge and if the high pressure drops too much injectors go past 6 and then it could be out of fuel and be lean.
Even though my high side drops to around 2500 at 5.5 and lamda or afr is still good Its good right?
Old 12-05-2022, 07:26 AM   #28
KingLT1
KingLT1's Avatar
Yes...People mention pressure drop as a point of reference as to where the weaklink might be in the system. The main thing is that the fuel is delivered within the 6ms. after that the fuel isn't burnt efficiently and you end up with some unburnt fuel going out the exhaust. It gets worse the higher above 6.0 the pulsewidths get.
2016 NFG 1SS A8
