05-13-2019, 09:06 AM | #1 |
Drives: 2016 2SS Join Date: Dec 2015
Brake fluid reservoir with screw-on cap?
To make a long story short, I hate the three-prong reservoir cap on my 2016 Camaro SS. It's nearly impossible to get a good seal with my Motive speed bleeder, and it only gets worse at the bleeder's gasket ages. My Focus ST had a threaded reservoir cap, and it worked so much better.
So I was reading on the motive website, and I found this: "Starting with some later Chevy cars, such as the new Camaro, have started to use a female threaded cap that screws on 1.5 to 2 full turns and is 45mm (1.75") inner diameter it will use the 1100 or 1109 adapter." That sounds great! The 1100 is the adapter that I used on my old ST. But is this actually true? Do any of you have a 6th gen Camaro with a brake fluid reservoir with a screw cap? If so, what year is your car? And if such a brake reservoir exists, does anyone know the PN? I did a quick browse on the GM parts websites, but the diagrams still look like three-prong twist caps, even on the 2018. (Though I know the diagrams on those part sites are not always the best.) |
05-13-2019, 08:56 PM | #2 |
Drives: 2017 2SS Manual Join Date: Apr 2017
My 2017 has the 3 prong cap as well. the metal adapter, version #1118 works ok for me up to 15 psi using the thicker gasket but it is hard to get on the reservoir.
The plastic adapter leaks no matter what I do |
05-17-2019, 09:39 AM | #3 |
Hmm...Not a lot of replies, so maybe to try a different way: people with 2019s, what kind of cap do you have on your reservoir?
Sent from my Pixel 3 using Tapatalk |
05-17-2019, 01:32 PM | #4 |
behold...
05-17-2019, 01:33 PM | #5 |
Damn. I wonder where Motive is getting their info.
05-17-2019, 03:27 PM | #6 |
The three prong adapter only fits leak free in 1 of the three possible positions. Once you install the motive adapter gently rock it and see if it is solidly attached. It will rock in the 2 bad positions. This is accurate for 5th & 6th gen cars. I discovered this after making a few mistakes and drowning my inner fenders with brake fluid.
05-21-2019, 08:41 PM | #7 | |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
So does the plastic cap work at all? Or is it useless?
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
06-01-2019, 06:48 PM | #8 |
plastic cap works fine if correctly clocked
