12-28-2018, 09:00 PM | #1 |
902HP 858TQ
Drives: 2018 ZL1 A10 Join Date: May 2018
Thermostat
Does anyone have a source for a 180 degree thermostat? Mine is stuck open
12-29-2018, 10:51 PM | #2 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I bought a 160 from mont Motorsports
12-30-2018, 06:55 AM | #3 |
902HP 858TQ
Thank You! I never thought it would be this hard to find one
12-30-2018, 08:11 AM | #4 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Is the thermostat on these hard to install?
2016 Challenger Hellcat /B5 blue/Sepia interior/Brass Monkey Wheels/
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
12-30-2018, 08:21 AM | #5 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
I assume it's not a hard change. But I have read getting the air out of the system is the biggest challenge. Some have to vacuum the air out. If you are stock. Let the dealer do it for free. Under warranty.
12-30-2018, 08:33 AM | #6 | |
How the hell can I swindle the dealership into believeing the stock thermostat is bad?
12-30-2018, 09:00 AM | #7 |
Drives: 2017 2lt rs Join Date: May 2017
You should be getting a trouble code P0128 or P0118 ECT.if the thermostat is stuck open.This is monitored by the Pcm.Should be a warranty job,if you trust your dealer
12-30-2018, 11:16 AM | #8 | |
I’m just looking to swap the stock one for a lower temperature one.
12-30-2018, 06:45 PM | #9 |
Kevin
Drives: 2018 Callaway Camaro ZL1 1LE Join Date: Apr 2018
You realize this will not lower engine temps by installing a lower thermostat only. You will require a tune for the fan to come on at a lower temp to allow for lower engine temps. If you just install a thermostat only it will open at a lower temp but the engine temp will still rise to the normal temp until the fan comes on. Installing a thermostat only does very little by itself to lower engine temps.
12-31-2018, 02:52 AM | #10 | |
I was interested since running coolant through the engine at a lower heat threshold still provides some benefit. On my Hellcat swapping the thermostat is a breeze I was curious to see how hard it would be on the Chevy. But Like you said, a lower temperature thermostat is not a significant difference until the tune is modified. I’ll jus wait till I decide to not care about warranty anymore.
12-31-2018, 05:31 PM | #11 | |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
03-17-2019, 08:28 AM | #12 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
I posted it in another thread but I think here is it better although I don’t have an ZL1.
So, the next season is coming and I’m thinking of changing the thermostat but is it really worth it for a normal 2SS? And can every stealer make the fan tune?
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
03-17-2019, 08:31 AM | #13 |
I got my 180 degree stat from Ted Jannetty
Baby Blue
03-20-2019, 10:58 AM | #14 |
Drives: 2018 ZL1 1LE Join Date: Apr 2018
The stock thermostat is built in to the housing, this is why there aren’t many options. What I did was change the housing to the Billit LS3 style which allows for drop in Thermostats and a ton more options.
I’m currently running a Lingenfelter 160 with my fan programmed to come on at 177 @ 20% duty cycle. At 185 it’s 50% and at 190 it’s 90%. In traffic on hot days I’ll see around 185 and while rolling above 30 it drops to closer to 170-175 but I’m also running a large C&R Racing Radiator. On track temps hover around 210-215 under load (800+ bhp) but more importantly since the oil is cooled by the engine coolant, my temps stay closer to 240 rather than the 280+ when I was stock. I hope this info helps |
