dave@hennessey
Old 07-13-2015, 03:03 PM   #1
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS For Sale
Cool Polished and Painted my strut bar
I painted the ends black, and polished the aluminum middle section. Think it came out good! Some pics are before polishing.
Edit:
This is the polish I use, works for any metal finish, use it on my exhaust tips often. Use old (soft) white t-shirts.
Wipe in circles, do not go side to side, although this polish is very forgiving, so no big deal if you have to do it near the ends. Takes some elbow grease.
http://www.detailedimage.com/Optimum...-P291/8-oz-S1/
And the black paint is just 4-5 coats of the black BBQ pit paint (I had some lying around). I wanted it flat black, and the BBQ paint is supposed to resilient. Cleaned the ends with brake cleaner first, masked off, and did a bunch of coats. That paint dries amazingly fast, so I just gave it 10-15 mins in between coats, using a crappy folding chair to support the middle so I could get around all the ends.
And for those worried about the bolts messing up the new paint, the good thing about the bolt is that the washer is captive, but not made into the bolt, so when you tighten, it doesn't turn on the metal and rip the new paint off.
vroomapunk is offline   Reply With Quote
Old 07-13-2015, 04:43 PM   #2
JMT
JMT's Avatar
Drives: 2013 1LT
How did you polish it? Products?
Looks great, I painted the ends the color of my car and would also like to polish the center section.
JMT is offline   Reply With Quote
Old 07-13-2015, 05:42 PM   #3
csmith4153
csmith4153's Avatar
Drives: 2011 1SS
nice
csmith4153 is offline   Reply With Quote
Old 07-13-2015, 06:27 PM   #4
Hurst
Camaros Of Northwest Ohio
Hurst's Avatar
Drives: 2013 SIM 2SS/RS, LS3
Nice... I want to know as well....
Hurst is offline   Reply With Quote
Old 07-13-2015, 07:01 PM   #5
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
Looks very nice!
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 07-13-2015, 09:27 PM   #6
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Damn you went at it with the polish better than me. I think I used 1500 and 2000 grit sandpaper to wet sand it. Then hit it with mother's mag and aluminum polish. Used rustoleum automotive enamel to spray the ends
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 07-13-2015, 09:40 PM   #7
Graphicsgod
Graphicsgod's Avatar
Drives: 2015 Manual Hot Red 2LS Camaro
Nice job guys!
I thought about polishing the middle, but couldn't get a good enough shine, so I just painted it. I think it came out good, even though I couldn't find a red that matches "Red Hot" ..
Just finished it today! Took me about two weeks and a lot of engine enamel paint. About five coats for each color.. For some odd reason I can't get the one bolt on the driver's side to go all the way down . Always seems to happen to me ! There is always that one damn bolt that doesn't want to go back into place...
Graphicsgod is offline   Reply With Quote
Old 07-13-2015, 11:51 PM   #8
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
I tried to do the same and my polish doesn't even look half as good !
Sapper12b is offline   Reply With Quote
Old 07-14-2015, 01:38 AM   #9
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
that shine is amazing
TommyTheCat is offline   Reply With Quote
Old 07-14-2015, 06:50 AM   #10
1QwkSS
Drives: 2012 Camaro 1SS M6
Looks great!!
1QwkSS is offline   Reply With Quote
Old 07-14-2015, 09:15 AM   #11
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Thanks everyone!! I should've used some 1500/2000 grit sandpaper first, would have saved me some time.
All I used is Optimum Metal Polish. I got it from Detailed Image. Its a pretty fine polish, I use it on exhaust tips monthly. Works on chrome wheels, etc too.
Apparently aluminum polishes off black, didn't realize that, so it left a lot behind and was hard to see through.
The best applicators I use, are actually just soft old white t-shirts. One to polish, and one to clean it off (in this case I needed three).
Link in the original post.
I will probably polish my throttle body next, as I need something else polished in the engine bay so the bar doesn't look out of place.
Old 07-14-2015, 09:27 AM   #12
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Yours looks great, I had a lot of patience with it, just watched tv and did in on the tile floor in my living room haha.
Originally Posted by Graphicsgod View Post
Nice job guys!
Looks awesome man, Im still considering paint one day. The threads get paint on them from the factory, might be your issue. If the car was ever in a wreck, could be a little off.
Old 07-14-2015, 06:21 PM   #13
1QwkSS
not gonna lie...seeing this thread made me do the same to mine today...i don't have a buffing pad on a bench grinder however so i used my DA polisher...did okay after 1500 & 2000 grit but once i get a buffing pad on my grinder it's on like donkey kong!!
Old 07-14-2015, 07:27 PM   #14
Bowtie-Bri
Bowtie-Bri's Avatar
Drives: 2013 Camaro 2SS RS Convt.
OP, I like what you did with yours using the flat black. Looks really nice!
I smoothed out the cast textured finish on the ends and painted them gloss black. I wet sanded the center section with 320 and 600 paper and followed it up with mothers aluminum polish to a chrome like finish. It takes alittle elbow grease but it's a cheap and affordable mod.
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
Bowtie-Bri is offline   Reply With Quote
