02-11-2012, 09:39 PM | #1 |
I goofed - I need some help
My awesome wife bought me a sparks SS grill emblem for christmas - I finally had some spare time to install it today. My big fat hands wouldn't fit through the grill, so I had to remove the shroud....I couldn't get the shroud back on, so I decided to loosen the hood latch (yes, stupid idea). Now my hood isn't flush (it's too low) when I try to close it. I'm 99% sure it wasn't like this before - and I've tried making minor adjustments to the latch, but nothing seems to be working. Any helpful advice on how to re-align the latch properly?
02-11-2012, 09:52 PM | #2 |
Drives: 2010 CAMARO SS Join Date: Apr 2010
it may be your hood stops .....the 4 black nobs may need adjusted up....it may be the inside ones
02-11-2012, 10:02 PM | #3 |
adjust the little rubber pieces that you had to take off to take the shroud off. unscrew them a little and you should be ok
02-11-2012, 10:05 PM | #4 |
I tweaked on the hood stops...and no luck....however, I think I've made some progress. I had the torx bolts tightened pretty tight - I backed those off and now the alignment is reaaaaly close, but it still seems off to me.
02-12-2012, 08:22 AM | #5 |
Drives: 2SS Black w/ Inferno Orange Stripes Join Date: Sep 2010
I had the same issue when I installed my light bar. Mess with the torx screws and the hood stops. Between the 2 it will work out. I had to loosen the torx a lot more than I thought they should be, but ended up lining up perfectly.
Similar Threads | ||||
AirRaid CAI causes 20HP *loss*???? | convert | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 253 | 05-06-2011 10:12 PM |
I think I goofed... :-( | allmotor | Cosmetics and Lighting Modification Discussions | 16 | 06-17-2010 04:41 PM |
Wrong car! RS deleted. Salesman goofed up | mmbarberoilman | Camaro Price | Ordering | Tracking | Dealers Discussions | 14 | 04-20-2009 07:31 PM |
