11-14-2023, 03:47 PM | #1 |
2022 Vivid Orange ZL1 1LE
Drives: Firebirds - 1970,1974,1997,1999 Join Date: May 2018
ZL1 1LE 6 speed gearing and rearend options
I have a 2022 ZL1 1LE with M6 transmission. I want to verify the gearing and rear-end ratio numbers:
#1 2.66 #2 1.78 #3 1.3 #4 1.0 #5 0.74 #6 0.5 3.91 rear-end I am read-lining in 4th on the road courses(126mph) before the end of the straights. Are there any rear end gear options, 3.55, 342, etc? Thanks for any corrections or suggestions. Bob |
11-14-2023, 08:30 PM | #2 |
Drives: ‘23 ZL1-1LE Join Date: Mar 2023
RPO-MH3
2.29 1ST Gear 1.61 2ND 1.21 3RD 1.00 4TH .82 5TH .68 6TH 3.73 Rear Gear |
11-14-2023, 08:37 PM | #3 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
Shift!
I use 5th gear quite a bit in mine.
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
11-14-2023, 08:52 PM | #4 |
Drives: '18 ram 1500 Join Date: Dec 2016
with stock gears you should be hitting 135 in 4th at redline.
2023 ZL1 Radiant Red 6 spd, pdr, carbon fiber hood
1100 10/28/22 2000 12/6/22 3400 12/17/22 TPW 1/9/23 delivered 2/7/23 |
11-15-2023, 09:51 PM | #5 |
High Speed on Road Course
Thanks for all the inputs. Shifting to fifth just before a 3rd gear 190 degree double apex turn is a little gutsy for me. I will give it a try earlier in the straight away. However the final drive of 3.73 is suspicious. There is no way I am doing 132mph, maybe 125 at the high end. I need some sort of after market PDR to check speed and RPM. I misspoke my max RPM is 6200 to 6500. I am a bit nervous about going higher I have already suffered a frozen lifter and 13 week repair cycle.
I also found different ratios for MH3/TR6060 depending on the model of Camaro and year so ??? I tried to paste results from a RPM/GEAR ratio/Speed/Tire app which did not work. I used 26.7 inch as a tire diameter. The 3rd speed with a ratio of 1.3 and a different straight away is right on at 102mph and 6500 rpm with 3.91 rear end. Motive Gear Performance Ring and Pinion Sets G886391 Ring and Pinion Gears, GM 8.6 in. IRS/218mm, AAM, 3.91:1 Ratio, 32-spline, Standard Rotation, Rear, Chevrolet, Set Part Number: MGR-G886391 I could NOT find any replacement 3.73 gear for a Chevy IRS Sorry for the rabbit hole. List of ratios from TrueCar for 2022 ZL1:
11-15-2023, 10:13 PM | #6 |
Unless your car is not a ZL1-1LE you have the MH-3 transmission which has the ratios I stated above. The rear diff contains a 3:73.
The ratios you have stated are in the ZL-1 which has the wide ratio transmission. The 1LE has the appropriate close ratio transmission. |
11-15-2023, 11:10 PM | #7 | |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
11-15-2023, 11:17 PM | #8 |
11-15-2023, 11:50 PM | #9 |
One other thing, you are looking at the incorrect gear set for your car. You have a 226mm Ring gear.
Reference above, Chevrolet service bulletin. Many references including the sticky information on this site regarding trans ratios are incorrect. Lots of misinformation. Since you’re in CA, you likely have the BCD brakes which are 398mm front vs 390 as shown in the service bulletin. Otherwise that bulletin should reflect all ZLE’s. |
12-01-2023, 07:33 PM | #10 | |
HOT ZLE 1LE hood mod
Thanks for the response. At 77 miles I drove it to CALLAWAY in LA to add their SC750 option. This requires a cutout and shaker hood mod. Very professional and clean. Runs about 665 RWHP. |
12-01-2023, 09:21 PM | #11 |
Drives: Camaro Zl1 Join Date: Jun 2023
sc750
the sc750 option advertises at 750hp.... are u saying that's to the crank? If so u can get more HP to the wheel with bolt ons.. im running headers/ maggie 2650r/ big gulp cold air / ron davis heat exchanger, and a tune i make 729hp to the wheel... I'm thinking you might've paid a little extra just for the key fobs, mats n badges... i'd rather have the hp.. Does it add value ? being a callaway camaro? Like a Hennesey? Also mind if im a bit honest? It just looks like theres a hole in ur hood... And like its missing the big supercharger coming out of it? it has a gen3 callaway supercharger? im guessing they've gone so far as to engineer their own ? How does it stack up against a magnusson? I do like the 3 year warrantee... was their an option to extend? Can u show us pictures of the badging? Can u take the car to any GM stealership for the warantee or is it something u have to go back to LA for ?
12-01-2023, 09:41 PM | #12 |
So this is really interesting to me as I’ve never heard of a Callaway Camaro. Knowing the quality and engineering of Callaway cars as well as the fact that it retains the OEM DEALER service tells me this is the gold standard. 50 state legal, very impressive. Although not mentioned in the literature, it makes me wonder if Callaway may have changed your gearing. My impression was that you had an OEM vehicle.
12-01-2023, 10:01 PM | #13 | |
12-02-2023, 08:26 AM | #14 |
Does Callaway use one of the big 3 blowers (maggie, Whipple, eddie)? I can't imagine that they developed their own.
Baby Blue
