AWE Tuning
Old 09-01-2017, 05:52 PM   #1
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
Has anyone had this issue? Toe bolt
Was doing my alighnment today and couldn't figure out why I couldn't get the toe to adjust on the right side. Looking at it the plates that the adjustment bolt lines up with have bowed out...
I was able to get it in spec but I can't get the camber I want cause then the toe will be way out.
http://https://flic.kr/p/XHF3JU
http://https://flic.kr/p/X3UYsN
#53 F Street
2022 Sponsor autocrossdigits.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
2022 Rapid Blue 1SS 1LE
2019 D Street national champion (2019 civic Type R)
apexit53 is offline   Reply With Quote
Old 09-01-2017, 07:38 PM   #2
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
Yup... however the first damn alignment shop I went to jacked mine up by using a air impact on those bolts and it bowed out the plates... I ended up buying the BMR adjustable toe rods fixed my problem.. Second alignment shop I went to helped me out and then some... Mine was on the right side
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/
Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA
Supercharged with Overkill Superchargers http://www.v6superchargers.com
Dustya is offline   Reply With Quote
Old 09-01-2017, 08:15 PM   #3
apexit53
apexit53's Avatar
Yep mine is the right side as well. No impact used here they just bowed. I can't use the bmr stuff since I need to keep this stock for autocross. Going to have to figure something out. Talking to my dealer next week and if they can't cover it I'll try and push them back in place...
#53 F Street
Autocrossing Videos
Old 09-01-2017, 09:08 PM   #4
Dustya
Problem is bending metal back and forth just makes it weaker.... and its attached to the subframe to boot so not easy to replace. Get a fatter washer that will reach out to the bowed part maybe?, this is the first thing my 2nd alignment shop tried and they almost got it back to normal but still could not.. You cant use adjustable toe rods for autocross ? Sorry not familiar with autocross rules.
Old 09-02-2017, 07:26 AM   #5
apexit53
apexit53's Avatar
I can't use aftermarket adjustments for the stock classes. I also have no plans to jump to a different class since the car is competitive in its stock form.
Well it does make me feel better that I'm not the only one this has happened to. I have an email into my Chevy service manager so I'll keep you posted on the outcome.
#53 F Street
Autocrossing Videos
Old 09-03-2017, 07:31 PM   #6
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Could you post the picture within the thread? That link doesn't work for me. I'm interested in understanding the issue you're having.
Old 09-04-2017, 12:51 PM   #7
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
+1 would like to see the pics.
Ryephile is offline   Reply With Quote
Old 09-04-2017, 08:32 PM   #8
apexit53
apexit53's Avatar
Crap sorry about that. Idk why flicker links don't work from my phone.
Mike Nachtigal is my flicker account name
#53 F Street
Autocrossing Videos
Old 09-05-2017, 08:07 AM   #9
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Here you go:
Untitled by mnachtigal53, on Flickr
Yea I'd say that's pretty blown out. Ouch. I have no idea if GM would warranty that. It is crap, but I'm also feeling the "you touched it so it's not covered" excuse being played. Send them to your dealership service manager and ask for advice.
Old 09-05-2017, 10:44 PM   #10
Lt Berserker
Drives: V6 1LE
Worst case scenario (if warranty won't cover) pull the bolt & collar and (in order to stay in FS) clean the metal up and run a weld a line just inside and take a Dremel to clean up the shape... Then respray to prevent corrosion... Interesting to see what the dealership says...
Lt Berserker is offline   Reply With Quote
Old 09-16-2017, 07:54 AM   #11
apexit53
apexit53's Avatar
Car is going in monday to have the service manager check it out in person.
#53 F Street
Autocrossing Videos
Old 09-16-2017, 11:47 AM   #12
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Ill send you mine for free if you need them
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails.
Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp
Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85
DELIVERED 12/29/15
http://youtube.com/bybcous " no talking only racing on my youtube"
bybcous is offline   Reply With Quote
Old 09-18-2017, 01:12 PM   #13
BMR Tech
BMR Tech's Avatar
Drives: 2016 Camaro 2SS
Contact me directly here at BMR Suspension and I can get you sorted out with a set of
TR007 toe rods to help remedy this situation.
813-986-9302 or frank@bmrsuspension.com
BMR Tech is offline   Reply With Quote
Old 09-18-2017, 02:25 PM   #14
apexit53
apexit53's Avatar
cant use those for autoX classing reasons but I thank you.
Car went into the shop today. They looked at it and they are having a body tech bend the tabs back in and maybe reinforce it with a bead of weld but im not sue there yet.
I had the car on floating plates but apparently they want no weight on it when adjusting it.
#53 F Street
Autocrossing Videos
