09-19-2019, 06:06 PM | #1 |
Drives: 2016 2SS Join Date: Mar 2018
Went to the track yesterday and was disappointed.
Took my 2016 2ss to the track yesterday and was expecting better numbers. Appreciate any input you guys have. Is this due to wheel spin? Here is a list of mods;
Edlebrock Eforce s/c Dynatech longtubes Dynatech highflow cats TSP custom grind cam (with supporting mods) LT4 fuel system Race star 17inch drag pack. ET street in the back and skinnies up front. The car puts down 643whp and 587wtq. |
09-19-2019, 06:24 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Apr 2017
No. Not due to wheelspin. You're at least 10mph and 1 full second short of where you should be. You need a new tuner...or datalog for him and let him make adjustments.
Trust me, I've been there. I had numbers almost identical to yours. Got a new tuner and solved all the issues. I had given my original tuner multiple chances, but in the end...I went elsewhere.
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. |
09-19-2019, 06:36 PM | #3 |
I emailed him my slips. I’m sure he’ll get back to me in the morning. I’ll see what he says. Appreciate your input.
09-19-2019, 11:05 PM | #4 |
Tactical Garage
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Your 60' is part of the problem 3/10ths or so. I guessing you need to adjust your shift mph, to shift at higher rpms and stay in the higher boost. Hard to say for sure without seeing the logs.
09-19-2019, 11:56 PM | #5 |
BAMF SS
You dont even need to see the logs to know it short shifted. OP obviously spun off the line, and when you spin off the line, it messes up all your shift points, as the computer tries to anticipate the next shift but its timing is thrown off by the wheel spin
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
09-20-2019, 06:14 AM | #6 |
Sorry, forgot to add the car is an M6. So I’m shifting too early?
09-20-2019, 06:23 AM | #7 | |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
My question is, why was it spinning with drag radials? Were you lined up correctly in the groove? Do you do a wet burnout or a dry burnout? |
09-20-2019, 06:38 AM | #8 |
It’s an 6spd. I was burning out just at the edge of the box. Partially wet/dry. I’m also thinking I may not have warmed up the tires long enough. A lot of people are mentioning shifting early. Maybe I need to take the rpms to just before redline?
09-20-2019, 07:18 AM | #9 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I dont think ps4s are the greatest for hooking with drag racing. I have the same tires, and almost always spin at the line., burnout or not.
09-20-2019, 08:16 AM | #10 |
Even if you spun a little....your trap speed is way low. I mean, you have 250 more RWHP than stock and you're only trapping 6 mph more. And only 4/10 quicker than stock. Your tuner has work to do.
09-20-2019, 08:39 AM | #11 |
No way that is making 643whp. It seems we are in a age where these dyno shops will get you a number but a car that doesn't live up to it. That car is trapping like a 460whp mild bolt-on NA car.
A legit 640whp in a full weight car is going to trap 130+ in all but the worst conditions. 1.8 60ft isn't terrible for a manual. Your tune likely needs a lot of work. I wouldn't even go back to that tuner....I would order HPtuners and have Rick Clarke remote tune it.
2016 NFG 1SS A8
09-20-2019, 08:45 AM | #12 |
Drives: 2012 2SS CAMARO 45th Join Date: Apr 2011
Your trap speed seems a bit low. Seems like a few factors might have held you up. Your 60ft didn't help out much and it was pretty warm the other day. You might have had some heat soak. If you want we'd be glad to look over your tune and we can get you on our dyno as well. When you shift does it every feel like it lags in a certain gear? Maybe at the beginning or end of a gear?
09-21-2019, 06:05 AM | #13 | |
As far as shifting early, I'm guessing that you'll want to shift somewhere around redline, or maybe even higher, depending on where your tuner set the rpm limiter. Do you have a dyno chart that shows the power curve? |
09-21-2019, 06:18 AM | #14 |
Agree, but I was just giving a real-world observation of the auto shifts getting messed up by spinning. My example was not launching on a dragstrip, rather, it was spinning in 2nd giving short-shift to 3rd. Unprepped surface and no burnout box.
