Old 05-22-2023, 05:21 PM   #1
2013ZL1FUN
2013ZL1FUN's Avatar
Drives: 2013 ZL1 Convertible A6 BRM
2013 V6 Camaro Oil Change Intervals
I have a friend that has the previously described car. He drives about 10K a year. He is the original owner. I can't seem to stress the importance of oil changes with him. Just how expensive is a timing chain replacement, because that seems to be the main complaint of a car of this type.
2013 ZL1 CONVERTIBLE BRM A6
OHIO
2013ZL1FUN is offline   Reply With Quote
Old 05-22-2023, 06:07 PM   #2
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The 2012 and up V6 (the years with the LFX engine) so far have not had any timing chain issues as long as the engine is taken care off. As for cost, googling shows parts to range between $800-$1k depending on where you buy them and quality of the parts and 7-8 hours labor. Depending on labor costs in your area it would be around $2k total. Now this is assuming that when the chain goes it doesn't break other stuff like valves and pistons (I don't know if the LFX is a non-interference engine or not) which will raise the price substantially.
Old 05-22-2023, 06:48 PM   #3
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
Oil changes are cheap. Engines are expensive.
ariZona28 is offline   Reply With Quote
Old 05-22-2023, 07:24 PM   #4
redcoats1976
mine is changed every 5,000 miles,pretty sure thats what GM recommends.
Old 05-22-2023, 11:38 PM   #5
joekono
joekono's Avatar
Drives: Camaro Convertible 2014 1LT
Amen ariZona28!!!
joekono is offline   Reply With Quote
Old 05-23-2023, 06:30 AM   #6
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
I haven't seen anything that states a particular mileage for the affected V6 cars. Not saying there isn't. I'm just not aware if it is.
AFAIK, GM recommends going off the oil life monitor on all their passenger cars/trucks. While you can always set your own schedule, I believe GM recalled applicable V6 cars to reset the OLM settings to give notice sooner to change oil. Which may or may not equate to 5K miles. Not sure if that was a good idea or not, but I assume they thought that was the "fix".
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 06-05-2023, 08:55 AM   #7
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
2014 scheduled maintenance is 7,500 miles. I change mine around 5-6k since that's usually how much I put on it each year (if that).
I believe the timing chain issue due to oil starvation was rectified a few model years ago, but it's still an issue if you neglect it long enough.
ElderJ is offline   Reply With Quote
Old 06-05-2023, 09:31 AM   #8
xstuntman
Drives: 2012 Victory Red LFX
Yep, the LFX in the Camaro did get the upgraded chains. If I had a '10 or '11 V6 I would use the best direct injection motor oil possible, the cleanable K&N oil filter, and likely change it every 2500 to 3000 miles. The oils gotta be rated for DI engines since these motors run FILTHY! I routinely run mine three quarters of a quart over too since you do not want those chains to ever be short on oil.
And I might be one of the lucky ones because I've read a lot on C5 about the sixes using oil but mines always the same level.
xstuntman is offline   Reply With Quote
Old 06-07-2023, 07:40 AM   #9
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
That year would be a LFX 3.6 engine, not the LLT 3.6 engine. GM upgraded the timing chain from the LLT to the LFX. The timing chain pins/holes would wear, thus stretching the timing chain. This is caused by the higher fuel dilution in the oil from direct injection. Our '15 Equinox has the LFX. When I change the oil, the viscosity is low and has a slight gas smell. Almost 140k miles at ~7.5k mile oil change intervals. So far, so good. Supertech 5W30 with AC Delco PF 63 oil filter. Filter could be different on the Camaro. Should use Dexos branded oil.
Badbubba is offline   Reply With Quote
Old 06-08-2023, 11:13 AM   #10
Nenous1
Drives: 2011 Camaro rs
I always change my oil every 3000 miles and clean both pcv...
Nenous1 is offline   Reply With Quote
Old 06-09-2023, 06:16 AM   #11
Dave-G
Dave-G's Avatar
Drives: 2011 RS/2LT- manual
As do I. Right at 3-3,500 miles and it gets changed with Mobil one full syn. I consider it cheap insurance.
Dave-G is offline   Reply With Quote
Old 06-09-2023, 11:24 AM   #12
PaulsSS
Drives: 15SS Camaro
6K with todays oils are a safe bet.
PaulsSS is offline   Reply With Quote
Old 06-09-2023, 11:36 AM   #13
Dave-G
Dave-G's Avatar
I absolutely agree. My concern is fuel dilution and loss of critical viscosity, so I err on the side of caution.
Old 06-09-2023, 12:05 PM   #14
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
Nothing bad can happen from changing the oil "too often" except for spending more on oil.
Even with the high quality of today's synthetic oils and how long they can last between needed changes.
My wife's new Toyota goes 10,000 miles between changes, which blew my mind initially but apparently that's pretty common for newer cars.
I still change mine every 3,000-ish miles or less because of track time and simply wanting the thing to last.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses.
Trawz is offline   Reply With Quote
