02-18-2024, 05:02 PM | #1 |
Drives: 2018 1SS 1LE Join Date: Jul 2020
"service rear axle" along with one exhaust flapper wigging out
2018 SS 1LE with 7k miles. Was planning on selling it this week. Drove fine two days ago for the test drive. This morning I start it (It has a battery that is less than 6 months old) and I get a "service rear axle" message. I googled it and seemed its a common issue to pop up once in a while. But along with the message, I hear noises from the rear of the car (I haven't moved yet).
I try a few restarts, and the message still appears. Seems to continually pop up while running. I went to the back to try and figure out where the noise was coming from. I initially assumed it was some solenoids or something in the e-diff. but it turns out its the driver side exhaust valve wigging out. Passenger side seems fine. https://youtu.be/HjLcQ6RWKcw Seems very odd that the two issues would appear at exactly the same moment when the car has been running flawlessly up until this point. No check engine light. Any ideas?
2018 1SS 1LE Hyper Blue
02-18-2024, 05:10 PM | #2 |
My guess is it’s pissed off, because it’s only been driven a little more than 1k per year? Maybe disconnect the battery for 10 or 15 minutes see if it smartens it up
02-18-2024, 07:23 PM | #3 |
Thank you Al Oppenheiser!
"Service rear axle" is a common false-positive fault when the system goes low voltage (commonly from a dead battery). Solution: disconnect the battery from the car and charge it up with a battery charger/tender. Reconnect, boot up the car in service mode, clear the bogus CEL codes, then start normally.
02-19-2024, 08:08 AM | #4 | |
I'll have to look up the service mode thing. Wasn't aware there was a service mode.
02-19-2024, 10:19 AM | #5 |
Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
Did something chew a couple wires?
02-26-2024, 01:58 PM | #6 |
Very doubtful. I've lived here 20 years and never had any evidence of rodents.
I left the battery disconnected a few days. Still the same thing. The message definitely seems tied to the valve issue. It only pops up when I hear the valve. Also oddly, seems to fix itself when you put it into gear (M/T). Not sure if that was just coincidence but I did it a couple times. The buyers bank wanted an emissions test, but I just disconnected the battery. I've already had major issues trying to get the evap test to run to the point where it was unregistered for 6 months until I moved out of a emissions area and didn't need one. So that deal went south. The stealer is looking like the only option here. I cringe just thinking about it.
02-28-2024, 08:40 PM | #7 | |
02-28-2024, 08:59 PM | #8 | |
Guess I'll take the hit and sell it as is.
02-28-2024, 09:31 PM | #9 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Wonder if you have some moisture in the trunk and have some the green wire crusties. Or maybe like a harness shorting to ground when ever the valve acts up. I really hate electrical issues. I would start by inspected every wire harness in the trunk and then under the rear end starting at the NPP.
02-28-2024, 09:43 PM | #10 | ||
Drives: 2016 2SS Convertible Join Date: May 2012
02-29-2024, 06:40 AM | #11 | |
No but that was my next troubleshooting step. I'm in the middle of moving and the car is at one house while all my tools are at the other house 2.5 hours away. I also had not researched if the two sides were the same part numbers
Additionally I found that there is a calibration for them in a service tool menu. I could see a low battery in the right conditions maybe scrambled the calibration. So looking at that avenue as well. That also means that the issue may get worse or at least present mixed results if you swap the actuator without recalibrating it. Haven't given up yet... Quote:
02-29-2024, 08:38 AM | #12 |
Who Needs to KNOW?
Wiring damage in rear wheel wells ?
ing for grip.
02-29-2024, 06:51 PM | #13 |
So I bought a "Creader Elite G" scan tool. Interface is a little clunky but I got it because google showed me a corvette forum thread that showed it had the MPP relearn ability.
I was able to do the relearn, but all it did was change the way it makes noise. Long story short, after seeing the hidden DTC with the chassis control module and the rear diff module that all had to do with communications and voltage levels, coupled with the turn signal randomly flashing fast and then normal, I am leaning towards a wiring issue....somewhere. Edit: I also feel like even in touring mode, the TC was allowing a significant amount of rear tire slip. Going around 90 deg turns, the e-diff screen never showed more than 1% slippage which seems odd as well but I don't really remember what it normally shows.
02-29-2024, 06:59 PM | #14 |
Do you have cheap ass LED lights anywhere on the car if so check them first.
