02-03-2014, 02:03 PM | #1 |
Drives: 2010 SS 6m, black on black. Join Date: Jul 2010
Diff Swap, Mix and match driveline
OK, so some of us like testing the limits of stock components and others like spending their dollars for the piece of mind. Either way, there's several good options for beefing up these rear-end components for street/strip.
I like the idea of swapping parts for cheap to get the performance I was looking for. But with all these different parts and lack of specs it gets confusing. Besides the driveshafts the ls3 and l99 diffs can be swapped correct? Is the zl1 diff is completely different? I assume the axles are different as well as the driveshaft. I know the hammerhead diff uses different axles and driveshaft than the the rest. Can anyone give me insight on what some options would be. right now i have DSS 1000hp axles on my stock diff. I need a driveshaft so I'm trying to plan out what my future diff upgrade or build could be. I want to stick with lower gearing like the L99 or even the zl1's. Then i'd like it to be rated to 1000hp. What would work best? Thanks guys
02-03-2014, 02:25 PM | #2 | |
Drives: Wagon Queen Family Truckster Join Date: Oct 2009
Yes, they can be swapped. We keep factory differentials with 3.45 and 3.91 on the shelf for those looking to do exactly what you are asking about
The L99 transmission is geared more aggressively than the manual transmission in the LS3 cars. So, you don't have to go with a gear that is as low in the L99 to achieve the same results with a slightly lower gear in the LS3. Example: A 3.73 in a L99 car is about like a 3.91 in the LS3. A 3.91 in an L99 is about like a 4.11 in the LS3 What is best is all going to depend on your goal. |
02-03-2014, 04:53 PM | #3 |
Drives: Black 2SS/RS M6 Join Date: Mar 2010
I did the ZL1 diff swap, with ZL1 axles and driveshaft and they are different. The diff bolts right up with no mods, there are some high hp ZL1's with the stock driveline and havent heard of any breaking the rears yet, for me the 3.73 gears and the larger ring gears are a little peace of mind. It comes down to what you want to spend and how much power you plan on making.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME MGW Short Throw Shifter Complete ZL1 Rearend Swap |
02-03-2014, 05:05 PM | #4 |
well for me the lower the final gear the better. I think i'm going to get the DSS Aluminum shaft. and keep an eye out for the l99 diff or a deal on some reinforced gears and posi. I wish i could do the zl1 swap but i already have the dss axles. If i ever strike the lotto ill send it all off to dss and get the right parts for the hammerhead. But if im correct the stock diff is the lightest still.
02-03-2014, 08:19 PM | #5 |
You could probably have them rebuild your axles to the ZL1 diff, but it's all about $ and what your power goals.
2010 LS3 2SS/RS M6
02-03-2014, 08:54 PM | #6 |
Drives: 2010 2SS Join Date: Sep 2012
i was told my level 4 1000hp DSS half shafts will fit a hammerhead when the time comes...thats why i bought them. dunno about the aluminum driveshaft thought. i doubt it.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
02-04-2014, 03:22 PM | #7 | |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
02-08-2014, 09:49 AM | #8 |
You talking about my shafts?? Will my true trac or 3.91s still work with a hammerhead?
