06-08-2013, 07:43 AM | #1 |
THOSE OF YOU INSTALLING YOUR OWN CAMS STEP INSIDE
Something everyone should be doing when installing a Cam in an LS engine is a Case Learn Procedure.
This is also called a Crank Learn Procedure. With your SCT device you have this Option, if not you will have to find someone with a capable Scanner, Tech2, HPtuners or EFI Live to Perform this function. What this does is Syncronize your Cam, and Crank Signals with the Computer. This should be done any time you change a Cam or Engine or after reflashing of a your computer. It is in the Special Functions portion of your SCT Tuner. The vehicle must be fully warmed up, parking brake on, and follow the on screen Prompts. I caution everyone that the fuel cut is 4K, be ready to let off the gas when it hits fuel cut, or if for some reason the system is not ready and goes right by it. Ted.
www.jannettyracing.com
06-08-2013, 08:16 AM | #2 |
Drives: 2011 Camaro 1SS Join Date: Dec 2011
Does your mail-order tune for cams do this already?? or is this in addition to your tunes?
06-08-2013, 08:53 AM | #3 | |
You must do this procedure after a Cam install. Ted.
06-08-2013, 09:12 AM | #4 |
Drives: '11 2SS/RS A6 Join Date: Apr 2011
".........or after reflashing of a your computer."
That sounds like we should do this even if we don't have a cam?? Does it?
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can |
06-08-2013, 09:15 AM | #5 | |
Ted.
06-09-2013, 08:29 AM | #6 |
Drives: 2010 Camaro 2SS/RS,LS3 Join Date: Oct 2010
Ted does the HP tuner have this function?
LS-3, ProCharger D1SC 665. rwhp /562. rwtq @ 9.3 psi |
06-09-2013, 09:43 AM | #7 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Yes it does sir.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
06-09-2013, 10:00 AM | #8 |
are there noticeable differences (performance-wise or drivability) to having the cam and crank signals syncronized?
06-09-2013, 10:10 AM | #9 |
Thanks. I don't understand the "fuel cut" statement in the OP. Would you please explain?
Performance Mods:
06-09-2013, 10:32 AM | #10 | ||
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
If it is like a second coat of wax, or to (fine tune a tune) with basic bolt ons, then is it a good idea for everyone who has tuned their car to do this?
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
06-09-2013, 10:54 AM | #11 |
.....exactly.....that is what I am trying to figure out. My car runs great (better) after the JRE tune but what do I really gain by doing this? I get the second coat of wax analogy but I would really like more details. I am sure Ted will fill us in.
I also wonder if there are any more "coats of wax" like this we can apply?
Performance Mods:
06-09-2013, 07:42 PM | #12 | |
Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
-uck I hate waxing. But if Ted says to wax. Then wax on it is. |
06-09-2013, 08:04 PM | #13 |
I'm sure if it wasn't done it would of thrown a code. Tech2 won't work with 5th gens.. The new GDS will.
632RWHP/556RWTQ
06-09-2013, 08:09 PM | #14 |
This procedure has been around a long time, pre ls1 acutally. It shouldn't be needed on a bolt on car with the stock cam and original ecm. Only if the ECM has been changed, new cam, new crank or new engine. Once its set, its there.
