dave@hennessey
Old 03-06-2015, 01:14 PM   #1
Orange 2010 Camaro
Orange 2010 Camaro's Avatar
Drives: 2010 2SS/RS Camaro
afe Pfadt Feather Light coil over System Question?
Does anyone know when the afe Pfadt Feather Light coil over system will again be available? They are now located in Corona California. You can see what Camaro & Corvette parts are now currently available at www.pfadtracing.com.
All The Best,
Orange 2010 Camaro
Orange 2010 Camaro is offline   Reply With Quote
Old 03-06-2015, 01:22 PM   #2
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
You can send AFE a PM directly and ask them. They are somewhere on this board.
Post up what you discover.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 03-06-2015, 01:26 PM   #3
Rob@WretchedMS
Drives: His Wife Crazy
I don't have any info on that, but if i hear anything concrete i'll let you know.
Rob@WretchedMS is offline   Reply With Quote
Old 03-06-2015, 04:08 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
They are supposed to be coming back but are not available yet.
Old 03-07-2015, 10:29 AM   #5
Orange 2010 Camaro
I e-mailed afe Pfadt products yesterday & was told by Marvin in customer service, that the Feather Light coil over system for the 5th. gen Camaro should be available the first week of April.
You can also call & talk to Scott as well in customer service, & have your name put on a (first production run) list if desired. You also can see all of the available Camaro & Corvette parts that are currently available at www.pfadtracing.com.
All The Best,
Orange 2010 Camaro
Old 03-09-2015, 11:28 AM   #6
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
How do these stack up compared to the other coilovers options on the market? About the time Pfadt went under was when I had the money to get these. I always liked the quality of their products.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
MGW Short Throw Shifter
Complete ZL1 Rearend Swap
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 03-09-2015, 02:07 PM   #7
aFe POWER
aFe POWER's Avatar
Drives: Camaro
A few things besides being a inverted coilover system, is one our coilovers have a BOA or (Ball on Axis) system which has a pivot top mounting bracket that provides no noise going over bumps. It provides less chances of breakage during stressful driving conditions because of it's wider range of movement, versus being stationary that can cause stress breakage and durability issues.
Two we use CIRC system which stands for (Concentric integrated Remote Canister) which basically is like some racing or high performance off road shocks that have a external gas canister that aids in stroke. Ours are internal towards the top, so you don't have to figure out a way to mount the extra canister and make it more of a burden. Helps with low speed bumps and high speed bumps and reaction. On top of that because our shock bodies are longer compared to other companies, our coilovers perform perfectly at stock ride height .
Plus our coilovers do reduce overall weight by 34lbs so your suspension has better reaction time as well, which we think is critical in track use or high performance driving.
aFe POWER is offline   Reply With Quote
Old 03-09-2015, 03:20 PM   #8
Stealth 2010 2SS/RS
Do the front coilover use the fe3 10mm or the fe4 12mm endlink bolt?
2010 LS3 2SS/RS M6
Old 03-09-2015, 06:09 PM   #9
aFe POWER
aFe POWER's Avatar
Drives: Camaro
It comes with the FE3 10mm endlink size, but can easily drilled out to the 12mm endlink size if you wished.
Old 03-17-2015, 05:23 AM   #10
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
Any changes to the drag coilovers and will they still be ready for an early April release?
2010 Camaro 2SS/RS Aqua Blue Metalllic (bolt-ons)
2020 Camaro 2SS/RS Satin Steel Metallic - Shock and Steel Edition 1 of 98 - A10 (bolt-ons)
2010 Camaro 2SS/RS IOM - 1,023 RWHP 813RWTQ (Previous Paxton Record Holder: 9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Trans TH400, Carlyle Racing 15" Conversion, ECS Vortech YSI-B, Fore Fuel System, ID1700, Gall Racing 427 C.I LSX, Mast 285CC Heads, HR Custom Cam
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 03-17-2015, 01:06 PM   #11
aFe POWER
aFe POWER's Avatar
Drives: Camaro
The drag coilovers will be the same as the previous ones.
