TireRack
Old 10-01-2013, 09:09 AM   #1
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Manul trans removal?
Is there a DYI for removing the m6? If not what are the first steps I should take, any helpful tips? Thanks
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 10-02-2013, 08:36 PM   #2
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
this should help. he asked me for some info.
http://www.camaro5.com/forums/showthread.php?t=282276
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
MGW Short Throw Shifter
Complete ZL1 Rearend Swap
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 10-02-2013, 11:33 PM   #3
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
I also used that thread when I removed my transmission for the first time last weekend. Its not crazy informative, but you'll get an idea and figure it out along the way. Tools I found necessary were a T60 Torx bit for the driveshaft (I used a 1/2 drive) and like 3 to 4 feet of 3/8's in. drive extensions. I utilized a headlamp on my nugget and a 3/8ths in drive wobbly with a 15 mil on it to get to all the transmission bolts. I used some duct tape to keep the wobbly from going limp lol... The hardest part will be dealing with the transmission oil cooler lines. My 2011 didn't come with a remote disconnect for the upper line. I disconnected them from the radiator and unbolted the line holding block from the A/C compressor. Dropped the tranny and slid it back. I used the same transmission jack that is mentioned in that post. Bought it at harbor freight for 100, well worth it. You'll also be removing your shifter from the transmission, so read up on that. The guy in that thread used a magnet to install the very top dead center xmsn bolt.. I used duct tape on the socket/bolt lol... worked first time go. If I think of anything else, I'll add a post.
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
