TireRack
Old 07-20-2013, 08:04 PM   #1
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
wideband data logging and sct
ok so I finally get my wideband bung welded in and just trying to make sure everything is working. I have an aem inline wideband uego controller, all other pids log just fine but the wide band just sits at 7.3 volts this can't be right and I'm almost positive I have it wired up right, white wire from wideband to yellow/orange. I have all the up to date sct drivers firmware, and using live links gen 2. I've put the equation in live links as (2.375*v)+7.3125. Any help or ideas would be greatly appreciated. Just trying to get everything set up to log for Ted.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
MGW Short Throw Shifter
Complete ZL1 Rearend Swap
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 07-20-2013, 08:07 PM   #2
Supercharged SS
Drives: 2010 Camaro
Originally Posted by Stealth 2010 2SS/RS View Post
ok so I finally get my wideband bung welded in and just trying to make sure everything is working. I have an aem inline wideband uego controller, all other pids log just fine but the wide band just sits at 7.3 volts this can't be right and I'm almost positive I have it wired up right, white wire from wideband to yellow/orange. I have all the up to date act drivers firmware, and using live links gen 2. I've put the equation in live links as (2.375*v)+7.3125. Any help or ideas would be greatly appreciated. Just trying to get everything set up to log for Ted.
Pm nyny69. He just did his up. He claims it works perfectly. But he also thinks his car is fast at 10.9!!
Supercharged SS is offline   Reply With Quote
Old 07-20-2013, 08:58 PM   #3
nyny69
Drives: 2010 IOM SS
Remember 40k for 1.1...... No thanks
nyny69 is offline   Reply With Quote
Old 07-20-2013, 09:03 PM   #4
nyny69
Drives: 2010 IOM SS
what firewire are you using. They can come in 2 different configurations. I metered mine out to figure which one I had. I'd suggest adding analog 2 to your pid list just in case yours is wired opposite. Mine will default to a voltage reading if I log without hooking it up. This seems like your problem
Old 07-20-2013, 09:09 PM   #5
Stealth 2010 2SS/RS
I'll have to give it a try in the morning. Your suggesting to wire the other analog together?
2010 LS3 2SS/RS M6
Old 07-20-2013, 09:16 PM   #6
nyny69
Drives: 2010 IOM SS
No. I'm just saying when setting up config file select both analog 1 & 2 . If you had the other firewire that uses the other configuration you wired up analog 2 instead of 1. If livelink doesn't see any readings from the analog it defaults to a solid reading.
Old 07-20-2013, 09:21 PM   #7
nyny69
Drives: 2010 IOM SS
Here is a link for the 2 different schemes.
http://www.tricktuners.com/forums/showthread.php?t=194
Old 07-20-2013, 09:29 PM   #8
Stealth 2010 2SS/RS
ok, thanks for the info.
2010 LS3 2SS/RS M6
Old 07-21-2013, 05:34 PM   #9
Stealth 2010 2SS/RS
nyny69 thanks for the help I found that my firewire cable didn't mach the two variations but found which wire are what and got it all working. Thanks.
2010 LS3 2SS/RS M6
