Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Transmissions
Old 07-02-2023, 02:00 PM   #43
Kamero6
Drives: 6th Gen LT1
Originally Posted by Dynamical View Post
Do you have a trans cooler on your LT1?
Yep, checked it before posting the message. Looks the same as the SS according to internet pictures.
Adding to the debate:
After researching I think the only thing missing in the LT1 are the Aux side coolant radiators. (only cools the water, so if water temp is ok, engine oil temp should be good too.)
But regarding transmission and engine oil cooling looks like we have the same equipment.
I also did some math and if drivetrain losses are 15-18%, 5% to 7% could be in the differential.
After certain amount of power, you will need differential cooling, since air flow through case won't dissipate that much heat.
7% of 430hp (not 455 since you already loose some in the transmission) is 30hp.
It would be the equivalent of a 22kw or 15 space heaters approx.
Hence the LT1 limited to 155mph probably doesn't need it.
Doing simple math with ChatGPT helping, if using 455hp takes you up to 175mph, you will only need 270hp to maintain 155mph. (Approx, if not accurate, lets say 300hp to be safe)
7% of 300hp is 21hp instead of 30hp, you can probably disspate that just with airflow throught the differential. Most cars reach 130/140mph and don't have diff cooling.
I would say this "lack of cooling" is more of a marketing stun that a necessity for 99% of the cars out there.
Kamero6 is offline   Reply With Quote
Old 07-02-2023, 02:10 PM   #44
Kamero6
Drives: 6th Gen LT1
Originally Posted by arpad_m View Post
You're right, here is the official TSB as confirmation.
That's the confirmation then. I would say it isn't high speed track capable. You can do autocross and low speed tracks and it should be fine. Only concerns could be high coolant temps or differential oil temps.
LT1 is 100% 1/4 mile capable without issues.
Anyway, after killing the tires and brakes in a track day, I'd say replacing the differential doesn't add much $$ to the bill
Old 07-02-2023, 07:59 PM   #45
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Thumbs up
Excellent find sir thank you
Dynamical is offline   Reply With Quote
Old 07-02-2023, 08:02 PM   #46
Dynamical
Dynamical's Avatar
Thank you for confirming
I am only interested in drag racing and a little fun on the street. Thats awesome if I picked up an LT1 I wouldnt have to install trans cooler although my original worries about these newer platforms still exist.
Old 07-11-2023, 07:23 PM   #47
Dynamical
Dynamical's Avatar
Thumbs up
Well since I just bought a 2022 Camaro LT1 A10 I may as well update and confirm that the A10 trans does in fact come with the trans cooler. I absolutely love that it does because now I don't have to install one when I get a higher stall unless i want to upgrade to the ZL1 trans cooler
Old 02-05-2024, 02:49 PM   #48
Kent A
Kent A's Avatar
Drives: 2023 Camaro LT-1
My '23 LT-1 w/10 speed has a tranny cooler.
oooh - was that politically correct?
Kent A is offline   Reply With Quote
Old 02-12-2024, 11:18 AM   #49
ZLElvira
Waiting 4 A Point By!
ZLElvira's Avatar
Drives: 2020 ZLE, C8 Z06-Z07 2LT Carbon
I am looking to figure out WHICH A10 equipped Camaro comes with the front tranny cooler but WITHOUT the rear differential cooler lines. I am wanting to separate the diff cooler from my transmission in an effort to isolate each system, Oil, Water (engine coolant), Transmission & Rear Axle Oil/Lubricant. Once these are separated, I can thermostatically control each within a range of operation for the given task.
If anyone has a VIN they are willing to share of an A10 Camaro without the diff cooler and with the trans cooler up front, please send me a DM here. I am looking for the OEM GM Part numbers for those lines. THANKS!!
ZLElvira is offline   Reply With Quote
Old 02-12-2024, 11:32 AM   #50
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
The only models without rear differential cooling are I4/v6 and only the v6 comes with the 10L60
https://www.camaro6.com/forums/showthread.php?t=584316
I don’t believe they came with transmission coolers, the I4/v6 1LE did come with transmission cooler but only came in M6 and with differential cooler
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is offline   Reply With Quote
Old 02-13-2024, 12:06 PM   #51
Dynamical
Dynamical's Avatar
My LT1 model A10 has the trans cooler. Does NOT have differential cooling.
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
FJB
Old 02-13-2024, 12:53 PM   #52
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I don’t believe SS or LT1 convertibles have differential cooling, but ZL1 convertibles do have differential cooling.
Mark114 is offline   Reply With Quote
Old 02-13-2024, 01:04 PM   #53
Bumbleboy92
Long hauler
You are right, I should’ve read the thread further back my bad
I’ll update my chart to add a footnote about LT1 diff coolers
I have a note in my sheet about the ZL1 convertibles, can’t remember about other models but I’d imagine it would be the same
2016 1LT v6
- Totaled
Happiness: Infinite
Old 02-20-2024, 07:01 AM   #54
ZLElvira
ZLElvira's Avatar
Cool
Thought I would share this video so everyone finding this thread will have a better understanding of the A10 cooling and what to look for if something I have experienced causes issues like I have.
I wanted to share something that has happened to my ZLE and has caused quite a bit of frustration tracking down the origin of oil vapor smoke from under the hood while driving the car. If you track or street drive your Camaro, it might be worth your time to check the aux cooler in front of the radiator for tiny stones/rocks getting caught between the cooler and the plastic mount holding it in place. Mine has two pin-holes that only come into play when the transmission temps exceed the 190-degree thermostat and begin to flow at higher pressures. This is why it was so hard to find, as driving easy on the highway, my trans temps never reach this temp, thus the oil leaking was intermittent to show up.
Old 02-20-2024, 07:53 AM   #55
Dynamical
Dynamical's Avatar
Great vid thanks for posting. All those lines from the transmission is one reason I wanted to get the LT1 model. One less thing to worry about. Also no NPP on the LT1 so there's no big loss in money when opted for aftermarket exhaust.
I haven't looked on my LT1 yet but I assume I do have the trans line going to the radiator. Not sure how I feel about that yet and if I'll separate them. On my old LS1 cars I always separated the trans from the radiator just in case of a leak developed, didn't want fluid mixing and I also believed the trans fluid stayed cooler. We used to call the radiator a "fluid warmer" On my 01SS I also had the power steering cooler which I separated from the cooling system. Thanks for posting dude
FJB
Old 02-20-2024, 08:02 AM   #56
ZLElvira
ZLElvira's Avatar
In my looking at the system for the cooling of the differential from the transmission... I noticed the two lines coming from the trans, going to the diff and the line from the Aux cooler going back to the transmission has a quick-connect near the rear of the transmission... so what I am wanting to know, is there a a short cross-over tube on those cars not equipped with rear-diff cooling that I can simply remove my hard lines going to the rear to bypass this with a factory part..???
Is there anyone here with a V6 and A10 who can get the part code off their transmission of the line connecting the two hard lines off the transmission?
