05-11-2021, 05:12 PM | #29 | |
www.jannettyracing.com
05-11-2021, 05:39 PM | #30 | |
Drives: 2015 M6 ZL1, 2012 silverado Join Date: Apr 2019
2015 M6 ZL1 Bright Yellow: Cold Aid Inductions intake, 2.55 Griptec pulley,Kooks headers with high flow cats, Borla Atak cat back, ID1050's, Aux pump, Flex Fuel sensor 635whp 633wtq
05-12-2021, 06:10 AM | #31 | |
Ted
05-12-2021, 10:14 AM | #32 |
Nice. I will have to get one.
05-12-2021, 08:37 PM | #33 |
Drives: ZL1 Join Date: Sep 2020
05-12-2021, 08:52 PM | #34 | |
The second chart shows the blue run a/f is getting richer exactly when your HP dips. Lean it up in that area. |
05-12-2021, 09:21 PM | #35 | ||
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Just odd overall. Cars with the 2.5 upper and these mods should be around 600 or a little more.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
05-13-2021, 06:19 AM | #36 |
Making 13psi. I have my tank half empty so I should be able to fill up with 93 soon and test the performance against my old dragy numbers.
05-13-2021, 12:14 PM | #37 | |
Around how much timing on 93 do you think it may want? I was out burning some E85 today trying to use it all so I can fill up with 93. I have 25 degrees on the E85 tune.
05-13-2021, 03:06 PM | #38 |
fo'shizZL1
Of course every car is different, but I would estimate somewhere in the 17-19 degree range.
05-14-2021, 10:36 AM | #39 | |
Looks like rain on top of my 16hr work days I may not get to it for a few days. I appreciate all the info
05-15-2021, 10:39 AM | #40 |
Learner of things
Drives: 2013 ZL1 M6 coupe, black Join Date: Dec 2017
When we switched my car from 93 to E85, we made sure the tune was 100% squared away and the car was happy on 93, then made all of the E85 adjustments in the alcohol adder table. We did it in steps, street tuning and e-mailing back and forth. We started with about 40%, then bumped it up to 55-60%, then 75%. 75% is about the best I can get out of the pumps in my area, and it's enough to get the full benefits. The car picked up an estimated 50-75whp over 93oct when we were finally able to get it on a dyno some months later.
Current 60-130 PB is 6.9, starting in 3rd gear. This was over 2 years ago and about 75whp less than the current setup. It was also with full interior, stock suspension, 20" wheels w/ street tires. I'm thinking it should do 6.5 or better now.
2013 M6. Cammed, straight piped, 17# boost, E85. Tuned by CHenry Motorsports. 825rwhp @ 6450, 812 rwtq @ 3500. Stock unported blower, stock heads, stock bottom end, stock throttle body. Boost only, no meth, no nitrous
05-16-2021, 08:23 AM | #41 | |
05-16-2021, 09:16 AM | #42 |
So I was able to fill up with 93 this morning. I was only able to get one 60-130 run in and two 60-100 runs.........All where slower than before I had the pulley put on. Something has to be wrong with this 93 tune. And if there is a problem with the 93 tune i have to question the E85 tune. While the E85 tune performs well, how do I know it should not be better.
below is my best and worst 60-130 before the pulley was installed. one is with two shifts one is with just one shift And now after the pulley install At some point I am going to try it a few more times and do it with just 3rd and 4th gear to rule out shifting. I will also do a few pulls and log iat temps and timing. iat temps never got high on the e85 tune so i doubt that will be the problem but timing might.
