Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
BeckyD @ James Martin Chevy
Old 10-02-2020, 07:29 AM   #1
Kildar1988
Drives: 2017 Camaro 2LT 1LE, 1962 Corvette
Windshield Washer Fluid Pump Replacement
Has anyone replaced a pump on the 2017 V6 1LE?
I have seen the replacement of the 2015 with the bottle on the drivers side. Mine is on the passenger side I dont want to assume its the same just on the other side but is it?
Kildar1988 is offline   Reply With Quote
Old 10-02-2020, 12:33 PM   #2
tom's2005gto
Drives: 2016 2SS A8 Convertible
I replaced my 16 SS removed wheel. Remove a couple torq bit screws from inner liner, tug liner out of way a bit. Tank just inside next to bottom of fender. Remove hose = fluid runs out. Remove harness. Pull out pump. Reverse process.
tom's2005gto is offline   Reply With Quote
Old 05-27-2021, 02:36 PM   #3
Nathan Murphy
Drives: BMW 3 Series GT
To be honest, over the past six months in my car, the wiper pump most often breaks down, which is either clogged or stops working altogether. The second common problem for me was the replacement of the wiper blades. I always bought rubber brushes, but this time, on the advice of the mechanic of my workshop, I read on the website https://www.carwindshields.info/best...e-wiper-blades information about silicone wiper brushes, which are more reliable than rubber brushes. I bought SilBlade Premium wiper blades, hopefully they will be reliable.
Nathan Murphy is offline   Reply With Quote
Old 06-12-2021, 07:53 PM   #4
parbreak
Drives: 2017 50th Camaro SS
I replaced mine with an Alky Control Meth Pump. LOL
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
