BeckyD @ James Martin Chevy
Old 09-10-2020, 06:35 PM   #1
tom's2005gto
Drives: 2016 2SS A8 Convertible
sway bar install torque specs?
I'm swapping in 1LE front and rear sway bars in to my 2016 SS. I've searched and find data ranging all over the place.
Can someone please confirm the sway bar mount nut torque? And the end link nut torque? I've ordered the Nord-Lock washers for the front end links. Anything else needed?
tom's2005gto is offline   Reply With Quote
Old 09-11-2020, 10:49 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
be carefull dont brake off the bolts for the actual sway bay mount it happen to me not fun!!
Old 09-11-2020, 01:38 PM   #3
tom's2005gto
exactly what I don't want to happen. I've read several threads, but no clear mention of what the torque specs are. Best I could determine is 16 and 35
Was hoping someone could verify.
Old 09-11-2020, 09:11 PM   #4
asthmamax11
asthmamax11's Avatar
Drives: 1SS Summit White 6 speed
Ouch
They broke over tightening or breaking the bolt loose ?
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Solo Performance Cat deletes and Axleback
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
Flow one 19" wheels wrapped in Mickey Thompsons
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Joy to drive this classic every day!
Daily Driver
asthmamax11 is offline   Reply With Quote
Old 09-12-2020, 09:32 AM   #5
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
tom, here you go
Front sway bar links: upper 89 lb-ft, lower 96 lb-ft
sway bar mount 16 lb-ft
Rear sway bar links, nut 32 lb-ft, bolt 43 lb-ft
sway bar mount 43 lb-ft
h018871 is offline   Reply With Quote
Old 09-12-2020, 10:36 AM   #6
tom's2005gto
Originally Posted by h018871 View Post
tom, here you go
Thanks Geoff
Old 09-12-2020, 06:20 PM   #7
h018871
Geoff
h018871's Avatar
Old 09-13-2020, 08:45 PM   #8
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
On initial install of my upgraded sways, one of the mounting studs for the front bar snapped off at less than 16 lb-ft. It sheared off flush and I had to drill it out. Fortunately I had a 10mm bolt of perfect length and greater strength that dropped right in. I was using a good Craftsman torque wrench so go easy when installing these!
Ventmaster is offline   Reply With Quote
Old 09-14-2020, 11:54 AM   #9
kropscamaro16
i didnt install them afe power did and not sure who tightened them but it happened and wasnt fun
