Old 04-11-2020, 10:59 AM   #1
appleman22
Drives: 2017 1ss 1le
Check you axle nuts!!!
Hey guys,
Just wanted to make an info post about loose rear axle nuts on our cars. My 1le had both rear axle nuts loose from the factory. The torque spec is 200ft-lbs and the nut is a 36mm. There are others who have had this problem on these boards. After I tightened mine, any drivetrain play i had has totally disappeared. It's worth checking.
appleman22 is offline   Reply With Quote
Old 04-11-2020, 11:12 AM   #2
Redlinez
Shifts under load
Redlinez's Avatar
Drives: 2020 Camaro 1SS 1LE rally green
Thanks a bunch. I might have that size socket from a VW I had.
24 Audi S3 prem plus, sport package
HPDE - southeast - JTI- solo, PCA- blue.
22 Suzuki GSX-S 1000GT blue
Redlinez is offline   Reply With Quote
Old 04-11-2020, 08:22 PM   #3
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Originally Posted by appleman22 View Post
Hey guys,
Are you reffering to the screws that hold the axle (cv shaft) onto the differential? Or are you talking about something else? I know they have had problems on some of the being loose I have only visually checked mine but I should probably torque them also. 200 ft-lbs is a lot of torque on a little screw like that, there are grade 10.9 though. I know the service manual isn't real clear on a torque value too, they seem to like to call the drive shaft a "propeller shaft" and the axle shafts as "drive shafts". Are you talking about the wheel hub nut?
And as far as the driveline slack going away, are you referring to the clunk whenever you are coasting and step on the gas again? (the electronic throttle and other things do a good job of masking this is some situations but you can still definitely feel it and it really ruins the experience of the car and makes it seem like a POS.
Or are you talking about the clunk/clang/rattle when you go from drive to reverse and back? I believe this is mostly up and down movement on the driveshaft since the middle carrier "bearing" lets it move around so much. I think its a 2 piece driveshaft with this ridiculously loose carrier support in the middle to try to minimize vibrations. But its funny how they go to these great lengths to try to minimize these vibrations but then they don't care at all about the way more highly noticeable clunk/clank/rattle of the driveshaft when you shift to drive from park/neutral. Its insane how no one cares about that it seems like but me. I would way rather have a slight barely noticeable vibration than the clunk/clang that makes the car feel like a big POS.
cmitchell17 is offline   Reply With Quote
Old 04-11-2020, 09:13 PM   #4
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
FWIW- here is some of the other chatter on them as well...
https://www.camaro6.com/forums/showt...highlight=nuts
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
driven2exceSS is offline   Reply With Quote
Old 04-11-2020, 09:17 PM   #5
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
Based on size he’s talking about the nut in the center of the rotor when you take off wheel
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 04-11-2020, 09:57 PM   #6
tom's2005gto
Drives: 2016 2SS A8 Convertible
yep, found both mine finger tight at best. I re tightened both and staked them.
tom's2005gto is offline   Reply With Quote
Old 04-11-2020, 10:54 PM   #7
Kerry
Drives: 2019 2SS Camaro
mine were tight 2019 2ss
Kerry is offline   Reply With Quote
Old 04-11-2020, 11:24 PM   #8
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Drives: 2020 2SS - A10, NPP, MRC, CAI
How is everyone "staking" them??? Is there a hole in the bolt to put a kotter pin??? I know my right one has backed off 5-10° from the factor marking, I recently bought a 36mm socket to tighten it...
Any feedback is greatly appreciated!
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
2SS Capt is offline   Reply With Quote
Old 04-12-2020, 07:27 AM   #9
appleman22
I'm talking about the 36mm nut on the face of the rotor when you remove the wheel. There really isn't a way to stake them unfortunately. If mine come loose again i'll either use some sort of nordlock washer and locktite or possible drill the axle out and use a cotter pin and castle nut. Either way i'm glad that people are takin the time to check them!! It's important that these nuts are tight!
Old 04-13-2020, 04:31 PM   #10
buck50
Drives: 2021 C8, 2022 Camaro 2SS
Guys, Thanks for the heads up. Checked mine and both were backed off some.
You can see how much the one moved in the photo, other had similar movement. Tightened back up but don't have 200 ft-lb torque wrench.
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022
3400 1/25/2022 TPW 1/31
3800 2/15/2022
4300 2/19/2022
4B00 3/04/2022
4000 3/8/2022
Delivered 3/9/2022
____________________________________
Order 6/01/2016 2017 2SS, NPP, 56R whls
3000 6/08/2016
3000 6/15/2016 TPW 7/18/2016
3400 7/7/2016
4200 7/25/2016
Delivered 7/28/2016
Sold May 2020
buck50 is offline   Reply With Quote
Old 04-13-2020, 04:34 PM   #11
appleman22
i'm happy that you were able to find they were loose before it became a problem. Is there any way to contact a moderator on here so we can try to "spread the word" about this issue. A loose axle nut can turn into a big safety issue, especially on cars that see track use.
Old 04-13-2020, 05:44 PM   #12
DIYguy
DIYguy's Avatar
Drives: 2017 Camaro 1LT
Thanks very much for posting this.
I just checked mine.
The driver's side was tight.
The passenger's side was maybe 5 degrees loose, but is now fully tightened.
I used a 36mm socket left over from my own VW days, a 24 inch breaker bar and about half of my 200 pounds (calibrated arm) .
About 47k miles on the car for reference.
Thanks again, very informative.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
DIYguy is offline   Reply With Quote
Old 04-13-2020, 09:32 PM   #13
Redlinez
Shifts under load
Redlinez's Avatar
You'll want to make sure it's a 6 pt socket. The 36mm I bought was 12 and it didn't fit tight. Mine was tight on the passenger side . 2020 SS
Old 04-14-2020, 12:05 AM   #14
ste1n
Drives: 2019 2SS
Do you guys have a better picture or a better explanation of where those bolts are? I am going to take my car to a tire shop to have my summer wheels put on and I would like to have the tech look at it but I don't know how can I explain it precisely.
ste1n is offline   Reply With Quote
